Salta al contenuto principale
How to Repair and Refinish Wooden Legs on Mirror
Cosa ti serve
  1. How to Repair and Refinish Wooden Legs on Mirror, How to Repair and Refinish Wooden Legs on Mirror: passo 1, immagine 1 di 3 How to Repair and Refinish Wooden Legs on Mirror, How to Repair and Refinish Wooden Legs on Mirror: passo 1, immagine 2 di 3 How to Repair and Refinish Wooden Legs on Mirror, How to Repair and Refinish Wooden Legs on Mirror: passo 1, immagine 3 di 3
    • Inspect the damage from the chew marks.
    • If you have a mirror that is attached to the wood, be sure to cover the mirror to prevent damage. You can use painter's tape and cardboard to secure the mirror from damage.
    • Look for finer areas with smaller chewed up marks.
  2. How to Repair and Refinish Wooden Legs on Mirror: passo 2, immagine 1 di 2 How to Repair and Refinish Wooden Legs on Mirror: passo 2, immagine 2 di 2
    • Sand and clean the wooden legs in need of repair.
    • Be sure to wipe away all excess dirt and debris before applying stain.
  3. How to Repair and Refinish Wooden Legs on Mirror: passo 3, immagine 1 di 3 How to Repair and Refinish Wooden Legs on Mirror: passo 3, immagine 2 di 3 How to Repair and Refinish Wooden Legs on Mirror: passo 3, immagine 3 di 3
    • Apply the wood filler using a putty knife or your fingers.
    • If you use your fingers, be sure to press the wood filler into the chewed marks
    • Then smooth over with your finger.
    • Wood filler does dry quickly, so work fast if you are not using gloves.
  4. How to Repair and Refinish Wooden Legs on Mirror: passo 4, immagine 1 di 1
    • Allow the wood filler to dry (anywhere from 15 minutes to 8 hours).
    • Be sure to read the instructions on the wood filler for the allotted amount of time.
  5. How to Repair and Refinish Wooden Legs on Mirror: passo 5, immagine 1 di 2 How to Repair and Refinish Wooden Legs on Mirror: passo 5, immagine 2 di 2
    • Sand the filled area that its height is level the surrounding wood.
    • Sand the wood filler until it becomes smooth.
    • Be sure to sand the wood filler to match the same height and angle of the shape of the legs or furniture.
  6. How to Repair and Refinish Wooden Legs on Mirror: passo 6, immagine 1 di 1
    • Match the stain to the wood using a scrap piece of wood.
    • Minwax is the best brand to use with a variety of stains.
    • If you are not using gloves, be careful when staining because it can take multiple washes to get the stain off your hands and clothing.
    • Use gloves when staining.
  7. How to Repair and Refinish Wooden Legs on Mirror: passo 7, immagine 1 di 2 How to Repair and Refinish Wooden Legs on Mirror: passo 7, immagine 2 di 2
    • Apply the stain to the wood using a small paintbrush.
    • Be sure to use a staining brush, you can find them in the aisle next to the stains.
  8. How to Repair and Refinish Wooden Legs on Mirror: passo 8, immagine 1 di 3 How to Repair and Refinish Wooden Legs on Mirror: passo 8, immagine 2 di 3 How to Repair and Refinish Wooden Legs on Mirror: passo 8, immagine 3 di 3
    • Allow the stain to dry (depends on the stain; oil: 12 hours avg or water-based: 3-4 hours).
    • It may appear shiny and wet, so keep the wood out of the way.
  9. How to Repair and Refinish Wooden Legs on Mirror: passo 9, immagine 1 di 1
    • Repeat steps 7-8 for the desired stain.
    • On this particular guide, the staining process took three coats.
  10. How to Repair and Refinish Wooden Legs on Mirror: passo 10, immagine 1 di 1
    • Apply polyurethane sealer and let dry completely for 24 hours before reassembly.
    • Be sure the read the back of the polyurethane sealer for the allotted time.
Conclusione
Don’t forget to reassemble your wooden furniture. In this guide, the mirror has two screws that secure the mirror to its stand.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 30
Tutti i Tempi: 696
