Salta al contenuto principale
How to Repair a Whiteboard Frame
Cosa ti serve
  1. How to Repair a Whiteboard Frame, How to Repair a Whiteboard Frame: passo 1, immagine 1 di 1
    • Gather all your tools which are listed in the tool area.
  2. How to Repair a Whiteboard Frame: passo 2, immagine 1 di 2 How to Repair a Whiteboard Frame: passo 2, immagine 2 di 2
    • Start by applying Goo Gone onto a paper towel to remove any sticky residue from the outside of the whiteboard.
  3. How to Repair a Whiteboard Frame: passo 3, immagine 1 di 3 How to Repair a Whiteboard Frame: passo 3, immagine 2 di 3 How to Repair a Whiteboard Frame: passo 3, immagine 3 di 3
    • Clean the surface using a multipurpose cleaner safe for wood to remove any remaining residue and debris
  4. How to Repair a Whiteboard Frame: passo 4, immagine 1 di 3 How to Repair a Whiteboard Frame: passo 4, immagine 2 di 3 How to Repair a Whiteboard Frame: passo 4, immagine 3 di 3
    • Apply an even amount of glue to each piece, then place them into position and wipe off any excess glue
  5. How to Repair a Whiteboard Frame: passo 5, immagine 1 di 1
    • Hold all the pieces together for a minute to allow the glue to set firmly.
  6. How to Repair a Whiteboard Frame: passo 6, immagine 1 di 3 How to Repair a Whiteboard Frame: passo 6, immagine 2 di 3 How to Repair a Whiteboard Frame: passo 6, immagine 3 di 3
    • Secure the pieces with clamps at the corners and wait for 24 hours to let the glue dry.
  7. How to Repair a Whiteboard Frame: passo 7, immagine 1 di 2 How to Repair a Whiteboard Frame: passo 7, immagine 2 di 2
    • After 24 Hours, remove the clamps carefully.
  8. How to Repair a Whiteboard Frame: passo 8, immagine 1 di 2 How to Repair a Whiteboard Frame: passo 8, immagine 2 di 2
    • After 24 hours, remove the clamps and sand down any rough corners if necessary.
  9. How to Repair a Whiteboard Frame: passo 9, immagine 1 di 2 How to Repair a Whiteboard Frame: passo 9, immagine 2 di 2
    • Touch up any areas on the whiteboard using black paint where needed.
  10. How to Repair a Whiteboard Frame: passo 10, immagine 1 di 1
    • Congratulations! Your whiteboard is now fixed and ready to use.
Conclusione
Jelena Drca
Membro da: 02/02/24
181 Reputazione
1 Guida realizzata
UC Davis, Team 3-9, Andersen Winter 2024 Membro di UC Davis, Team 3-9, Andersen Winter 2024
UCD-ANDERSEN-W24S3G9
3 Membri
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 34
Tutti i Tempi: 521
