Salta al contenuto principale
How to Repair a Sole Delamination From the Midsole
Cosa ti serve
  1. How to Repair a Sole Delamination From the Midsole, Check the damaged area: passo 1, immagine 1 di 2 How to Repair a Sole Delamination From the Midsole, Check the damaged area: passo 1, immagine 2 di 2
    • Identify the part of the midsole that needs to be repaired.
  2. How to Repair a Sole Delamination From the Midsole, Remove glue residue: passo 2, immagine 1 di 2 How to Repair a Sole Delamination From the Midsole, Remove glue residue: passo 2, immagine 2 di 2
    • Use a rough piece of sandpaper to rub-off the remaining glue residue and to roughen the surface for enhanced glue adhesion.
    • Be careful not to damage the material below the midsole.
  3. How to Repair a Sole Delamination From the Midsole, Prepare the Shoe Glue: passo 3, immagine 1 di 3 How to Repair a Sole Delamination From the Midsole, Prepare the Shoe Glue: passo 3, immagine 2 di 3 How to Repair a Sole Delamination From the Midsole, Prepare the Shoe Glue: passo 3, immagine 3 di 3
    • Apply the glue to both the sole and the separated part.
    • Apply pressure using clamps.
    • Note: Follow the instructions of the glue used to know the exact drying time. In this example we left the product to dry overnight.
  4. How to Repair a Sole Delamination From the Midsole, Finished and ready!: passo 4, immagine 1 di 1
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusione
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
Membro da: 07/19/23
10.230 Reputazione
66 Guide realizzate
INTERSPORT Membro di INTERSPORT
Community
25 Membri
169 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 80
Tutti i Tempi: 812
