Salta al contenuto principale
How to Repair a Small Hole in Your Clothing
Cosa ti serve
  1. How to Repair a Small Hole in Your Clothing, How to Repair a Small Hole in Your Clothing: passo 1, immagine 1 di 1
    • Grab the clothing you want to fix and lay it on a table.
  2. How to Repair a Small Hole in Your Clothing: passo 2, immagine 1 di 1
    • Find the thread that matches the colour of the clothing you are going to repair.
    • Measure and cut a piece of string a minimum of 20x the length of the hole.
  3. How to Repair a Small Hole in Your Clothing: passo 3, immagine 1 di 3 How to Repair a Small Hole in Your Clothing: passo 3, immagine 2 di 3 How to Repair a Small Hole in Your Clothing: passo 3, immagine 3 di 3
    • Insert the thread through the eye of the needle.
  4. How to Repair a Small Hole in Your Clothing: passo 4, immagine 1 di 3 How to Repair a Small Hole in Your Clothing: passo 4, immagine 2 di 3 How to Repair a Small Hole in Your Clothing: passo 4, immagine 3 di 3
    • Pull the thread through until the length of both ends of the thread are the same length.
    • Tie the ends in a double knot.
  5. How to Repair a Small Hole in Your Clothing: passo 5, immagine 1 di 3 How to Repair a Small Hole in Your Clothing: passo 5, immagine 2 di 3 How to Repair a Small Hole in Your Clothing: passo 5, immagine 3 di 3
    • Pinch the fabric to close the hole, and weave the needle back and forth through the pinch until the hole is sealed.
  6. How to Repair a Small Hole in Your Clothing: passo 6, immagine 1 di 2 How to Repair a Small Hole in Your Clothing: passo 6, immagine 2 di 2
    • Cut the thread from the needle and cut the leftover thread on both ends of the sealed hole.
  7. How to Repair a Small Hole in Your Clothing: passo 7, immagine 1 di 1
    • The hole is completely sealed!
Linea Traguardo
Ann
Membro da: 09/19/20
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 46
Ultimi 30 Giorni: 211
Tutti i Tempi: 4,842
