Salta al contenuto principale
How to Repair a Silent Wall Clock Mechanism
Cosa ti serve
  1. How to Repair a Silent Wall Clock Mechanism, How to Repair a Silent Wall Clock Mechanism: passo 1, immagine 1 di 1
    • Using a screwdriver, remove all the screws on the back of the clock.
  2. How to Repair a Silent Wall Clock Mechanism: passo 2, immagine 1 di 1
    • Use your fingers to pry up one end of the battery and remove it from the clock.
  3. How to Repair a Silent Wall Clock Mechanism: passo 3, immagine 1 di 1
    • Clean the battery terminals in the battery compartment using isopropyl alcohol and a cotton swab.
  4. How to Repair a Silent Wall Clock Mechanism: passo 4, immagine 1 di 1
    • Dry the battery terminals with a clean cloth or paper towels so the terminals are not wet when a new battery is being inserted.
  5. How to Repair a Silent Wall Clock Mechanism: passo 5, immagine 1 di 1
    • Once the terminals have dried up, remove the glass lens covering the faceplate of the clock to make any adjustments.
  6. How to Repair a Silent Wall Clock Mechanism: passo 6, immagine 1 di 1
    • Turn the display face up, ensuring the clock hands do not touch each other.
    • Correct the time by moving the hands of the clock and inserting the new battery.
  7. How to Repair a Silent Wall Clock Mechanism: passo 7, immagine 1 di 1
    • Put the faceplate back on and assemble all of the pieces of the clock.
Conclusione
Altre 5 persone hanno completato questa guida.
2 Commenti
catellano por favor.gracias.
mario oscar Fiori - Replica
You don't need to open the clock to set the time - just turn that circle dial on the backside of the clock! What is this guide "fixing" anyway??
Ari - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 44
Ultimi 30 Giorni: 196
Tutti i Tempi: 5,315
