Salta al contenuto principale
How to Repair a Shirt Collar
Cosa ti serve
  1. How to Repair a Shirt Collar, How to Repair a Shirt Collar: passo 1, immagine 1 di 1
    • Use a seam ripper to completely unstitch the collar.
  2. How to Repair a Shirt Collar: passo 2, immagine 1 di 2 How to Repair a Shirt Collar: passo 2, immagine 2 di 2
    • Cut a piece of fabric the size of the damaged area, and place it over the interior of the damaged section of the collar.
    • Sewing machines can be dangerous; be sure to always keep your hands clear of the needle's path.
    • Sew the piece of fabric into the collar.
  3. How to Repair a Shirt Collar: passo 3, immagine 1 di 3 How to Repair a Shirt Collar: passo 3, immagine 2 di 3 How to Repair a Shirt Collar: passo 3, immagine 3 di 3
    • Fold your shirt and its altered collar in half, then mark the middle of the pieces with a fabric pencil.
    • This will be handy when stitching the pieces back together.
  4. How to Repair a Shirt Collar: passo 4, immagine 1 di 2 How to Repair a Shirt Collar: passo 4, immagine 2 di 2
    • Place the fragment of the collar that was altered, the side facing your neck, in the opposite direction.
  5. How to Repair a Shirt Collar: passo 5, immagine 1 di 2 How to Repair a Shirt Collar: passo 5, immagine 2 di 2
    • Stitch the pieces back together.
    • To simplify the process, add pins beside the path that will be stitched, or just follow the marks of the previous seams that you unstitched in the first step.
  6. How to Repair a Shirt Collar: passo 6, immagine 1 di 1
    • Steam irons are extremely hot and can cause burns.
    • Iron the area to settle the new stitching.
Conclusione
Enjoy your like-new collar!
1Commento della guida
It used to be the case when you bought a shirt that it would come with a spare collar and cuff. When the collar started to fray you could take it to your local tailor and they would change the collar for you. While no longer included when you buy a shirt you can repair a shirt collar yourself or if you can't sew there are services like collarreplacement.com that will do this for you.
Vintage - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 169
Tutti i Tempi: 3,795
