Salta al contenuto principale
How to Repair a Scratched CD
Cosa ti serve
  1. How to Repair a Scratched CD, How to Repair a Scratched CD: passo 1, immagine 1 di 1
    • Rinse the disc with water and wipe clean to remove any dust or dirt.
  2. How to Repair a Scratched CD: passo 2, immagine 1 di 3 How to Repair a Scratched CD: passo 2, immagine 2 di 3 How to Repair a Scratched CD: passo 2, immagine 3 di 3
    • Apply a rubbing compound, moving from the center of the disc outwards.
    • Use enough force to create a mirror polished surface when rubbing compound application is complete.
    • We found that applying the rubbing compound for at least 30 seconds to 1 minute is sufficient.
  3. How to Repair a Scratched CD: passo 3, immagine 1 di 1
    • Let the CD sit for 5 minutes.
  4. How to Repair a Scratched CD: passo 4, immagine 1 di 2 How to Repair a Scratched CD: passo 4, immagine 2 di 2
    • Wipe the CD clean with a new rag, removing any excess compound.
  5. How to Repair a Scratched CD: passo 5, immagine 1 di 3 How to Repair a Scratched CD: passo 5, immagine 2 di 3 How to Repair a Scratched CD: passo 5, immagine 3 di 3
    • Apply a thin coat of car wax directly to the CD, using a circular application method.
    • Apply in either small circular motions or large motions that follow the circumference of the disc.
  6. How to Repair a Scratched CD: passo 6, immagine 1 di 2 How to Repair a Scratched CD: passo 6, immagine 2 di 2
    • Wipe the CD clean, removing any excess wax.
Conclusione
Congratulations! You have successfully repaired the scratched CD!
Altre 8 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 37
Ultimi 30 Giorni: 169
Tutti i Tempi: 15,482
