Salta al contenuto principale
How to Repair a Round Head Ratchet
Cosa ti serve
  1. How to Repair a Round Head Ratchet, How to Repair a Round Head Ratchet: passo 1, immagine 1 di 3 How to Repair a Round Head Ratchet, How to Repair a Round Head Ratchet: passo 1, immagine 2 di 3 How to Repair a Round Head Ratchet, How to Repair a Round Head Ratchet: passo 1, immagine 3 di 3
    • Remove the direction selector dial by turning it counterclockwise with a T15 screwdriver.
  2. How to Repair a Round Head Ratchet: passo 2, immagine 1 di 3 How to Repair a Round Head Ratchet: passo 2, immagine 2 di 3 How to Repair a Round Head Ratchet: passo 2, immagine 3 di 3
    • Lift up on the direction selector dial to remove it.
    • Be careful to keep the heart spring in place during removal.
  3. How to Repair a Round Head Ratchet: passo 3, immagine 1 di 3 How to Repair a Round Head Ratchet: passo 3, immagine 2 di 3 How to Repair a Round Head Ratchet: passo 3, immagine 3 di 3
    • Lift up on the heart spring to remove it.
  4. How to Repair a Round Head Ratchet: passo 4, immagine 1 di 3 How to Repair a Round Head Ratchet: passo 4, immagine 2 di 3 How to Repair a Round Head Ratchet: passo 4, immagine 3 di 3
    • Remove the pawl and anvil by sliding them out of the ratchet handle.
  5. How to Repair a Round Head Ratchet: passo 5, immagine 1 di 1
    • Clean all the old grease and dirt off the parts with a rag.
  6. How to Repair a Round Head Ratchet: passo 6, immagine 1 di 2 How to Repair a Round Head Ratchet: passo 6, immagine 2 di 2
    • Lubricate the pawl and the teeth in the head of the ratchet handle with a light coat of multi-purpose grease.
  7. How to Repair a Round Head Ratchet: passo 7, immagine 1 di 3 How to Repair a Round Head Ratchet: passo 7, immagine 2 di 3 How to Repair a Round Head Ratchet: passo 7, immagine 3 di 3
    • Reinstall the anvil and pawl by sliding them into the ratchet handle.
  8. How to Repair a Round Head Ratchet: passo 8, immagine 1 di 3 How to Repair a Round Head Ratchet: passo 8, immagine 2 di 3 How to Repair a Round Head Ratchet: passo 8, immagine 3 di 3
    • Reinstall the heart spring by sliding the end of the spring into the hole in the pawl.
  9. How to Repair a Round Head Ratchet: passo 9, immagine 1 di 3 How to Repair a Round Head Ratchet: passo 9, immagine 2 di 3 How to Repair a Round Head Ratchet: passo 9, immagine 3 di 3
    • Reinstall the direction selector dial, being careful to place the stud on the dial within the loop of the heart spring.
  10. How to Repair a Round Head Ratchet: passo 10, immagine 1 di 3 How to Repair a Round Head Ratchet: passo 10, immagine 2 di 3 How to Repair a Round Head Ratchet: passo 10, immagine 3 di 3
    • Reinstall the direction selector dial screw and tighten in a clockwise direction with a T15 screwdriver.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
2 Commenti
Very clear and accurate, especially for the spring shape and its positioning in installation, which helped me to fix the problem with it.
Jason Zou - Replica
Perfect pictures and descriptions! My wrench is working again! Thanks!!!
John B. - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 44
Ultimi 30 Giorni: 160
Tutti i Tempi: 4,310
