Introduzione
If your Qianlong Rolling Office Chair is loose and wobbly and/or missing screws, this guide will show you how to repair it! There are no special requirements for this fix, other than having prior knowledge on how to use a wrench. After completing this guide, your chair should be working properly in no time!
Cosa ti serve
Carefully turn the chair over onto its side so that you have clear access to the underside of the seat.
Remove the old bolts and hardware by unscrewing each bolt with your torque wrench, turning counterclockwise. We will be replacing them with new ones.
Place a flat washer in front of one of the holes and make sure it lines up.
Carefully insert one of the bolts through the washer and into the hole. Use your index and thumb to tighten the bolt as much as possible, by turning it clockwise. Doing so makes it easier to tighten with your wrench later.
