Salta al contenuto principale
How to Repair a Patio Solar Light
Cosa ti serve
  1. How to Repair a Patio Solar Light, How to Repair a Patio Solar Light: passo 1, immagine 1 di 1
    • Disassemble the circuit box using a Phillips screwdriver.
  2. How to Repair a Patio Solar Light: passo 2, immagine 1 di 1
    • Using a multimeter, put the black wire in the COM port, and the red wire into the far right port. Set the switch to 20 volts DC.
  3. How to Repair a Patio Solar Light: passo 3, immagine 1 di 1
    • Remove battery from the port.
    • Check both ends of the battery with the multimeter.
    • The red prong touches the negative side, and the black prong touches the positive side of the battery.
  4. How to Repair a Patio Solar Light: passo 4, immagine 1 di 1
    • Ensure that the multimeter screen shows a number that matches or is greater than the voltage of the battery. If not, replace the battery.
    • Check the circuit board for detached, or loosely connected wires.
  5. How to Repair a Patio Solar Light: passo 5, immagine 1 di 3 How to Repair a Patio Solar Light: passo 5, immagine 2 di 3 How to Repair a Patio Solar Light: passo 5, immagine 3 di 3
    • Use a soldering iron at 400 Celsius to melt your soldering wire. Gather a droplet on the tip of the soldering iron, and use the drop to reattach the disconnected wire back onto the circuit board.
    • CAUTION: Don't handle metal parts of the soldering iron without proper gloves and protection.
  6. How to Repair a Patio Solar Light: passo 6, immagine 1 di 1
    • Turn your solar light back on before reassembling to test if it’s working properly.
    • When the light turns on, reassemble your solar light.
Conclusione
Miguel Antonio Gonzales
Membro da: 02/20/24
133 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 48
Tutti i Tempi: 609
