Salta al contenuto principale
How to Repair a Loose Rear Bicycle Wheel
Cosa ti serve
  1. How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: passo 1, immagine 1 di 3 How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: passo 1, immagine 2 di 3 How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: passo 1, immagine 3 di 3
    • Loosen the rear axle.
    • Turn the bike around, and loosen the brake arm.
  2. How to Repair a Loose Rear Bicycle Wheel: passo 2, immagine 1 di 2 How to Repair a Loose Rear Bicycle Wheel: passo 2, immagine 2 di 2
    • Take the chain off the gear and take out the wheel.
  3. How to Repair a Loose Rear Bicycle Wheel: passo 3, immagine 1 di 2 How to Repair a Loose Rear Bicycle Wheel: passo 3, immagine 2 di 2
    • Assess damage of the dropout and wheel.
  4. How to Repair a Loose Rear Bicycle Wheel: passo 4, immagine 1 di 2 How to Repair a Loose Rear Bicycle Wheel: passo 4, immagine 2 di 2
    • Properly set the wheel back into dropout and put the chain back on the gear.
  5. How to Repair a Loose Rear Bicycle Wheel: passo 5, immagine 1 di 2 How to Repair a Loose Rear Bicycle Wheel: passo 5, immagine 2 di 2
    • Pull on the wheel so that the chain is tight, while tightening the rear axle just enough to hold it in place.
  6. How to Repair a Loose Rear Bicycle Wheel: passo 6, immagine 1 di 3 How to Repair a Loose Rear Bicycle Wheel: passo 6, immagine 2 di 3 How to Repair a Loose Rear Bicycle Wheel: passo 6, immagine 3 di 3
    • Check for misalignment or frame rubbing by pedaling without resistance.
  7. How to Repair a Loose Rear Bicycle Wheel: passo 7, immagine 1 di 3 How to Repair a Loose Rear Bicycle Wheel: passo 7, immagine 2 di 3 How to Repair a Loose Rear Bicycle Wheel: passo 7, immagine 3 di 3
    • Fully tighten the axle.
    • Turn the bike around.
    • Reattach the brake arm.
Conclusione
Lily Suggs
Membro da: 01/31/23
145 Reputazione
1 Guida realizzata
UC Davis, Team 4-8, Andersen Winter 2023 Membro di UC Davis, Team 4-8, Andersen Winter 2023
UCD-ANDERSEN-W23S4G8
3 Membri
1 Guida realizzata
Un commento
Axle alignment is crooked, which can cause wobbling. Loosen the axle nuts or quick-release skewer, align the wheel, and tighten it securely.
Bruno John - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 68
Tutti i Tempi: 742
