Salta al contenuto principale
How to Repair a Loose Modern Gooseneck Water Faucet
Cosa ti serve
  1. How to Repair a Loose Modern Gooseneck Water Faucet, How to Repair a Loose Modern Gooseneck Water Faucet: passo 1, immagine 1 di 3 How to Repair a Loose Modern Gooseneck Water Faucet, How to Repair a Loose Modern Gooseneck Water Faucet: passo 1, immagine 2 di 3 How to Repair a Loose Modern Gooseneck Water Faucet, How to Repair a Loose Modern Gooseneck Water Faucet: passo 1, immagine 3 di 3
    • On the bottom of the sink, you will see a water tank.
    • The next step is to close the vault. Slowly turn the vault to the right side.
    • You can see the vault is 90 degrees opposite to the direction when it was opened. That means it is now closed.
  2. How to Repair a Loose Modern Gooseneck Water Faucet: passo 2, immagine 1 di 3 How to Repair a Loose Modern Gooseneck Water Faucet: passo 2, immagine 2 di 3 How to Repair a Loose Modern Gooseneck Water Faucet: passo 2, immagine 3 di 3
    • Check again by opening the tap to see if water is coming out of it or not.
    • Due to the loose neck, water is leaking from the sink.
    • The leakage can cause damage in the future, so, it is necessary to tighten the loose neck of the water dispenser.
  3. How to Repair a Loose Modern Gooseneck Water Faucet: passo 3, immagine 1 di 3 How to Repair a Loose Modern Gooseneck Water Faucet: passo 3, immagine 2 di 3 How to Repair a Loose Modern Gooseneck Water Faucet: passo 3, immagine 3 di 3
    • Readjust the pipe to the way it was originally.
    • Make sure the realignment is properly done and that there are no gaps in it.
    • After, check the realignment from all sides so there are no places from where it can leak.
  4. How to Repair a Loose Modern Gooseneck Water Faucet: passo 4, immagine 1 di 3 How to Repair a Loose Modern Gooseneck Water Faucet: passo 4, immagine 2 di 3 How to Repair a Loose Modern Gooseneck Water Faucet: passo 4, immagine 3 di 3
    • Use a wrench to adjust and tighten the screw on the right side to secure it in place.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 16
Tutti i Tempi: 210
