Salta al contenuto principale
How to Repair a Locket Hinge
Cosa ti serve
  1. How to Repair a Locket Hinge, How to Repair a Locket Hinge: passo 1, immagine 1 di 3 How to Repair a Locket Hinge, How to Repair a Locket Hinge: passo 1, immagine 2 di 3 How to Repair a Locket Hinge, How to Repair a Locket Hinge: passo 1, immagine 3 di 3
    • Use pliers to carefully bend the damaged hinge back into place.
    • You want the hinge to be rounded and hollow, like a straw.
    • Test the hinge with some wire. If you can easily thread the wire through, then you can move on to Step 2. If not, keep bending.
  2. How to Repair a Locket Hinge: passo 2, immagine 1 di 3 How to Repair a Locket Hinge: passo 2, immagine 2 di 3 How to Repair a Locket Hinge: passo 2, immagine 3 di 3
    • Hold both ends of the wire.
    • Place the middle of the wire against a hard edge. Hold the wire so that it is perpendicular to the edge.
    • Straighten the wire by pulling it against the edge.
  3. How to Repair a Locket Hinge: passo 3, immagine 1 di 2 How to Repair a Locket Hinge: passo 3, immagine 2 di 2
    • Bend the wire to match the contours of your locket.
    • If your locket is rounded, your wire will have to be curved. If your locket is straight, your wire will have to be straight.
  4. How to Repair a Locket Hinge: passo 4, immagine 1 di 2 How to Repair a Locket Hinge: passo 4, immagine 2 di 2
    • Cut the wire to a manageable length. We suggest the length of the hinges plus some excess.
  5. How to Repair a Locket Hinge: passo 5, immagine 1 di 3 How to Repair a Locket Hinge: passo 5, immagine 2 di 3 How to Repair a Locket Hinge: passo 5, immagine 3 di 3
    • Match and align the front and back of the locket.
    • The holes of the hinge must be aligned, making a tunnel for the wire.
    • Line up the curved wire to match the locket shape.
    • Feed the wire through the hole of the hinge.
  6. How to Repair a Locket Hinge: passo 6, immagine 1 di 3 How to Repair a Locket Hinge: passo 6, immagine 2 di 3 How to Repair a Locket Hinge: passo 6, immagine 3 di 3
    • Hold the locket closed.
    • Glue the top of the hinge.
    • Glue the bottom of the hinge.
    • Do not glue the center of the hinge.
  7. How to Repair a Locket Hinge: passo 7, immagine 1 di 2 How to Repair a Locket Hinge: passo 7, immagine 2 di 2
    • Hold the locket closed and hammer the side with the hinge and wire.
    • Tap firmly along the hinge and wire to secure.
  8. How to Repair a Locket Hinge: passo 8, immagine 1 di 2 How to Repair a Locket Hinge: passo 8, immagine 2 di 2
    • Cut the excess wire.
  9. How to Repair a Locket Hinge: passo 9, immagine 1 di 2 How to Repair a Locket Hinge: passo 9, immagine 2 di 2
    • The final product, the locket hinge is fixed and the locket can be used.
Linea Traguardo
Daisy J Williams
Membro da: 01/31/24
169 Reputazione
1 Guida realizzata
UC Davis, Team 4-3, Andersen Winter 2024 Membro di UC Davis, Team 4-3, Andersen Winter 2024
UCD-ANDERSEN-W24S4G3
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 21
Tutti i Tempi: 111
