Salta al contenuto principale
How to Repair a Knotted Chain
Cosa ti serve
  1. How to Repair a Knotted Chain, How to Repair a Knotted Chain: passo 1, immagine 1 di 1
    • Find a flat surface.
    • Remove all clutter from your workspace to ensure you can access the chain easily.
    • The flat surface will provide stability when you begin working through the tangles and will prevent other tangles from forming during the process.
  2. How to Repair a Knotted Chain: passo 2, immagine 1 di 3 How to Repair a Knotted Chain: passo 2, immagine 2 di 3 How to Repair a Knotted Chain: passo 2, immagine 3 di 3
    • Rest the chain on the surface.
    • Slowly spread the chain out so you can recognize the tangled areas.
    • While spreading the chain on the surface, make sure to do so slowly in order to avoid tightening the tangle.
  3. How to Repair a Knotted Chain: passo 3, immagine 1 di 3 How to Repair a Knotted Chain: passo 3, immagine 2 di 3 How to Repair a Knotted Chain: passo 3, immagine 3 di 3
    • Unclasp the chain.
    • Separate the strands gently.
    • Opening the clasp will isolate the chain strands, permitting them to slide through the knots easily.
  4. How to Repair a Knotted Chain: passo 4, immagine 1 di 2 How to Repair a Knotted Chain: passo 4, immagine 2 di 2
    • Gently sprinkle baby powder onto the knotted area.
    • Sprinkle the powder until the knot is lightly coated.
    • This is an optional step.
  5. How to Repair a Knotted Chain: passo 5, immagine 1 di 3 How to Repair a Knotted Chain: passo 5, immagine 2 di 3 How to Repair a Knotted Chain: passo 5, immagine 3 di 3
    • Bring your thumb and index finger into a pinching pose.
    • Put the knot between the thumb and index finger.
    • Carefully and gently lightly rub the knot together.
  6. How to Repair a Knotted Chain: passo 6, immagine 1 di 2 How to Repair a Knotted Chain: passo 6, immagine 2 di 2
    • Insert two toothpicks between the focal point of the knot.
    • Any fine toothpick style tool can work to untangle the knot.
  7. How to Repair a Knotted Chain: passo 7, immagine 1 di 3 How to Repair a Knotted Chain: passo 7, immagine 2 di 3 How to Repair a Knotted Chain: passo 7, immagine 3 di 3
    • Gently draw the toothpicks from one another to open and release the tight knot.
    • When you get an opening in the knot using the toothpicks, take it apart by pulling each separated strand through the knot to fully open it.
    • Then slowly pull apart the loosened knot to separate the chain strands.
  8. How to Repair a Knotted Chain: passo 8, immagine 1 di 2 How to Repair a Knotted Chain: passo 8, immagine 2 di 2
    • Restore chain back into its original form.
    • Clasp the chain to avoid it from re-tangling.
  9. How to Repair a Knotted Chain: passo 9, immagine 1 di 2 How to Repair a Knotted Chain: passo 9, immagine 2 di 2
    • Wipe the chain with a damp towel or tissue before use.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 23
Tutti i Tempi: 846
