Introduzione
While applying perfume, one may press down too hard causing the nozzle or sprayer to be jammed. This repair project involves a step-by-step procedure guide on how to fix a jammed nozzle on a perfume bottle. This repair requires you take extra safety precautions when removing the nozzle because the bottle is made of glass which can break easily if not gently handled.
Cosa ti serve
Remove the nozzle from the bottle by taking the pliers and unscrewing the nozzle counterclockwise.
To reassemble the perfume bottle, follow these instructions in reverse order.
Altre 6 persone hanno completato questa guida.
5 Commenti
complimenti, bell'articolo!
This guide is stupid. BEFORE DOING THIS expose the nozzle and insert a sewing needle directly without removing the entire gasket. Don't cause unnecessary damage as most bottles have crimpted gaskets and are irremovable.
hey stupid dont talk $@$* and do a video. I need to see it,
Thanks now a needle is stuck in the tube
