Salta al contenuto principale
How to Repair a Hole in an Inflatable Floatie
Cosa ti serve
  1. How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: passo 1, immagine 1 di 3 How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: passo 1, immagine 2 di 3 How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: passo 1, immagine 3 di 3
    • If the punctured area is not obvious:
    • Spritz soapy water over different areas of the inflated floatie and press down on the floatie until you see air bubbles.
  2. How to Repair a Hole in an Inflatable Floatie: passo 2, immagine 1 di 2 How to Repair a Hole in an Inflatable Floatie: passo 2, immagine 2 di 2
    • Deflate the floatie by pinching the base of the valve stem and pressing down on the floatie to let the air out.
  3. How to Repair a Hole in an Inflatable Floatie: passo 3, immagine 1 di 3 How to Repair a Hole in an Inflatable Floatie: passo 3, immagine 2 di 3 How to Repair a Hole in an Inflatable Floatie: passo 3, immagine 3 di 3
    • Clean the punctured area with alcohol wipes in order to help the waterproof tape adhere better.
    • Wait for the alcohol to completely dry.
    • If you do not have alcohol wipes available feel free to use soap, water and a towel. Then let the area dry completely.
  4. How to Repair a Hole in an Inflatable Floatie: passo 4, immagine 1 di 3 How to Repair a Hole in an Inflatable Floatie: passo 4, immagine 2 di 3 How to Repair a Hole in an Inflatable Floatie: passo 4, immagine 3 di 3
    • Cut the waterproof tape two centimeters wider than the punctured area.
    • You can cut the waterproof tape in a circle or square; whichever you prefer.
  5. How to Repair a Hole in an Inflatable Floatie: passo 5, immagine 1 di 3 How to Repair a Hole in an Inflatable Floatie: passo 5, immagine 2 di 3 How to Repair a Hole in an Inflatable Floatie: passo 5, immagine 3 di 3
    • Peel off the backing of the waterproof tape and center it over the punctured area.
    • Make sure the area is flat that way the waterproof tape will have less air bubbles when applied.
  6. How to Repair a Hole in an Inflatable Floatie: passo 6, immagine 1 di 2 How to Repair a Hole in an Inflatable Floatie: passo 6, immagine 2 di 2
    • Press down firmly on the patch making sure no air bubbles are visible.
    • Leave it for about 30 minutes.
    • Inflate your floatie and enjoy the water!
Conclusione
Enjoy your renewed floatie!
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 183
