Salta al contenuto principale
How to Repair a Hole in a Duvet Insert
Cosa ti serve
  1. How to Repair a Hole in a Duvet Insert, How to Repair a Hole in a Duvet Insert: passo 1, immagine 1 di 1
    • Remove the duvet cover from the insert and locate the hole.
  2. How to Repair a Hole in a Duvet Insert: passo 2, immagine 1 di 1
    • Cut a piece of scrap fabric slightly larger than the hole.
  3. How to Repair a Hole in a Duvet Insert: passo 3, immagine 1 di 1
    • Insert the fabric inside the hole, making sure the fabric covers the entirety of the opening.
  4. How to Repair a Hole in a Duvet Insert: passo 4, immagine 1 di 1
    • Carefully pin the patch in place, ensuring the entire opening is covered and secure.
  5. How to Repair a Hole in a Duvet Insert: passo 5, immagine 1 di 1
    • Insert thread in the needle hole and tie a slip knot at the end of the thread.
    • Keep extra thread pulled through the needle to prevent it from unthreading. If it does, re-thread and continue.
  6. How to Repair a Hole in a Duvet Insert: passo 6, immagine 1 di 3 How to Repair a Hole in a Duvet Insert: passo 6, immagine 2 di 3 How to Repair a Hole in a Duvet Insert: passo 6, immagine 3 di 3
    • Insert the needle in one of the corners of your patch, being sure to pierce through both the duvet insert and patch.
    • Continue stitching around the perimeter of the patch with stitches around 1/4 of an inch long until you have reached your previous starting point.
  7. How to Repair a Hole in a Duvet Insert: passo 7, immagine 1 di 2 How to Repair a Hole in a Duvet Insert: passo 7, immagine 2 di 2
    • Sew around the hole's edges to secure the duvet insert into the patch to prevent future tearing.
  8. How to Repair a Hole in a Duvet Insert: passo 8, immagine 1 di 3 How to Repair a Hole in a Duvet Insert: passo 8, immagine 2 di 3 How to Repair a Hole in a Duvet Insert: passo 8, immagine 3 di 3
    • Once finished, tie 1-2 knots and cut the thread off.
    • Make sure to leave 1/4 inch between the cut and the knot to prevent the knot from coming undone.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
UC Davis, Team 3-3, Vidal-Chiesa Fall 2024 Membro di UC Davis, Team 3-3, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S3G3
3 Membri
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 28
Tutti i Tempi: 252
