Salta al contenuto principale
How to Repair a Hole in the Wall Using Spackle
Cosa ti serve
  1. How to Repair a Hole in  the Wall Using Spackle, How to Repair a Hole in  the Wall Using Spackle: passo 1, immagine 1 di 3 How to Repair a Hole in  the Wall Using Spackle, How to Repair a Hole in  the Wall Using Spackle: passo 1, immagine 2 di 3 How to Repair a Hole in  the Wall Using Spackle, How to Repair a Hole in  the Wall Using Spackle: passo 1, immagine 3 di 3
    • Prepare the damaged surface by cleaning and removing all dust and debris.
    • If the surface has a wallpaper, remove it for a length more extensive than the mesh patch.
  2. How to Repair a Hole in  the Wall Using Spackle: passo 2, immagine 1 di 3 How to Repair a Hole in  the Wall Using Spackle: passo 2, immagine 2 di 3 How to Repair a Hole in  the Wall Using Spackle: passo 2, immagine 3 di 3
    • Apply the self-Adhesive patch by peeling back the paper liner from the patch and apply it over the hole.
    • Press patch firmly to ensure a strong bond to the wall.
  3. How to Repair a Hole in  the Wall Using Spackle: passo 3, immagine 1 di 3 How to Repair a Hole in  the Wall Using Spackle: passo 3, immagine 2 di 3 How to Repair a Hole in  the Wall Using Spackle: passo 3, immagine 3 di 3
    • Open container and mix spackling compound before applying.
    • Mix thoroughly to have a smooth application.
  4. How to Repair a Hole in  the Wall Using Spackle: passo 4, immagine 1 di 3 How to Repair a Hole in  the Wall Using Spackle: passo 4, immagine 2 di 3 How to Repair a Hole in  the Wall Using Spackle: passo 4, immagine 3 di 3
    • Use the putty knife to spread spackling compound evenly over the adhesive patch.
    • Spread the spackling mixture beyond the area intended to cover.
    • Apply thinner layers toward the edges of the patch, so the patched area blends with the wall.
  5. How to Repair a Hole in  the Wall Using Spackle: passo 5, immagine 1 di 2 How to Repair a Hole in  the Wall Using Spackle: passo 5, immagine 2 di 2
    • Allow the compound to dry completely before moving to the last step.
    • Depending on the hole's size and thickness of the layers applied, it might take a while to dry.
  6. How to Repair a Hole in  the Wall Using Spackle: passo 6, immagine 1 di 3 How to Repair a Hole in  the Wall Using Spackle: passo 6, immagine 2 di 3 How to Repair a Hole in  the Wall Using Spackle: passo 6, immagine 3 di 3
    • Once the spackling compound has dried, sand it lightly with a sand pad/sponge.
    • Smooth out any bumps on the surface.
    • Do not sand down to mesh patch.
    • Once the surface is smooth, paint, wallpaper, or apply any texture desire.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 195
Tutti i Tempi: 3,988
