Salta al contenuto principale
How to Repair a Guitar Wall Mount
Cosa ti serve
  1. How to Repair a Guitar Wall Mount, How to Repair a Guitar Wall Mount: passo 1, immagine 1 di 2 How to Repair a Guitar Wall Mount, How to Repair a Guitar Wall Mount: passo 1, immagine 2 di 2
    • If the swivel mechanism on the arm of your guitar wall mount is hanging down and isn't responding to pressure, odds are the arm has become disengaged from the gears.
  2. How to Repair a Guitar Wall Mount: passo 2, immagine 1 di 3 How to Repair a Guitar Wall Mount: passo 2, immagine 2 di 3 How to Repair a Guitar Wall Mount: passo 2, immagine 3 di 3
    • Remove the loose arm.
  3. How to Repair a Guitar Wall Mount: passo 3, immagine 1 di 2 How to Repair a Guitar Wall Mount: passo 3, immagine 2 di 2
    • Remove the two 6.5 mm screws from the mount with a Phillips #2 screwdriver.
    • Remove the whole mount from the wall.
  4. How to Repair a Guitar Wall Mount: passo 4, immagine 1 di 2 How to Repair a Guitar Wall Mount: passo 4, immagine 2 di 2
    • Insert the arm's shaft inside the marked circle.
    • Make sure that the gears in the bracket are aligned.
  5. How to Repair a Guitar Wall Mount: passo 5, immagine 1 di 2 How to Repair a Guitar Wall Mount: passo 5, immagine 2 di 2
    • The mount should look like this after correctly inserting the loose arm piece.
  6. How to Repair a Guitar Wall Mount: passo 6, immagine 1 di 3 How to Repair a Guitar Wall Mount: passo 6, immagine 2 di 3 How to Repair a Guitar Wall Mount: passo 6, immagine 3 di 3
    • Make sure the arms swivel appropriately with pressure and without pressure.
Conclusione
Screw your mount back onto the wall, and you're good-to-go!
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 206
