Salta al contenuto principale
How to Repair a Damaged Action Figure
Cosa ti serve
  1. How to Repair a Damaged Action Figure, How to Repair a Damaged Action Figure: passo 1, immagine 1 di 1
    • Clean the figurine and wash your hands before starting.
  2. How to Repair a Damaged Action Figure: passo 2, immagine 1 di 1
    • Identify the broken parts and apply a small drop of super glue on the area needing a fix.
    • CAUTION: AVOID DIRECT SKIN CONTACT WITH THE GLUE. Glue can cause skin irritation or burns.
  3. How to Repair a Damaged Action Figure: passo 3, immagine 1 di 2 How to Repair a Damaged Action Figure: passo 3, immagine 2 di 2
    • Press the two pieces together and make sure they match. Hold them together tightly for 2 minutes.
    • If any glue leaks outside when pressing, use an alcohol wipe to clean it.
  4. How to Repair a Damaged Action Figure: passo 4, immagine 1 di 1
    • Let the glue settle and dry for a minimum of 1 hour.
  5. How to Repair a Damaged Action Figure: passo 5, immagine 1 di 1
    • Use acrylic paint as necessary for patching chipped sections of the plastic.
  6. How to Repair a Damaged Action Figure: passo 6, immagine 1 di 1
    • Allow the paint to fully dry before attempting to move or adjust the figurine.
    • You can use hair dryer to speed up the drying process.
Conclusione
UC Davis, Team 3-8, Andersen Winter 2023 Membro di UC Davis, Team 3-8, Andersen Winter 2023
UCD-ANDERSEN-W23S3G8
4 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 75
Tutti i Tempi: 1,658
