Salta al contenuto principale
How to Repair a Cracked Flower Pot
Cosa ti serve
  1. How to Repair a Cracked Flower Pot, How to Repair a Cracked Flower Pot: passo 1, immagine 1 di 2 How to Repair a Cracked Flower Pot, How to Repair a Cracked Flower Pot: passo 1, immagine 2 di 2
    • Remove any contents from the pot.
  2. How to Repair a Cracked Flower Pot: passo 2, immagine 1 di 1
    • Apply craft adhesive along the broken portion of the pot.
    • Warning: your adhesive may be flammable. Carefully read the cautions listed on your adhesive before proceeding.
  3. How to Repair a Cracked Flower Pot: passo 3, immagine 1 di 3 How to Repair a Cracked Flower Pot: passo 3, immagine 2 di 3 How to Repair a Cracked Flower Pot: passo 3, immagine 3 di 3
    • Begin to apply glue onto the broken pieces.
    • Once you apply glue to a piece, attach it to the pot.
  4. How to Repair a Cracked Flower Pot: passo 4, immagine 1 di 3 How to Repair a Cracked Flower Pot: passo 4, immagine 2 di 3 How to Repair a Cracked Flower Pot: passo 4, immagine 3 di 3
    • Scrape away the excess glue on both the outside and inside of the pot with scrap paper.
    • Make sure to do this before the glue dries completely.
  5. How to Repair a Cracked Flower Pot: passo 5, immagine 1 di 2 How to Repair a Cracked Flower Pot: passo 5, immagine 2 di 2
    • Use a shoelace or twine to tightly hold the pot together while it dries.
    • Depending on your glue, drying time may take up to 24-72 hours.
  6. How to Repair a Cracked Flower Pot: passo 6, immagine 1 di 3 How to Repair a Cracked Flower Pot: passo 6, immagine 2 di 3 How to Repair a Cracked Flower Pot: passo 6, immagine 3 di 3
    • Once your adhesive has finished drying, remove the shoelace or twine.
  7. How to Repair a Cracked Flower Pot: passo 7, immagine 1 di 2 How to Repair a Cracked Flower Pot: passo 7, immagine 2 di 2
    • Return your plant to its pot.
Conclusione
Now your flower pot is fixed and ready to be used!
Irene Amuyunzu
Membro da: 10/26/18
148 Reputazione
1 Guida realizzata
UC Davis, Team S1-G6, Bender Fall 2018 Membro di UC Davis, Team S1-G6, Bender Fall 2018
UCD-BENDER-F18S1G6
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 53
Tutti i Tempi: 3,253
