Salta al contenuto principale
How to Repair a Crack on a Vittorazi Moster Exhaust
Cosa ti serve
  1. How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: passo 1, immagine 1 di 3 How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: passo 1, immagine 2 di 3 How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: passo 1, immagine 3 di 3
    • Use a 10mm open wrench to lossen the three exhaust mounting points.
    • Locate the nuts that need to be adjusted and make sure you you have the proper tools, stated earlier to ensure they can loosen.
    • Once you have found the nuts, use your 10mm wrench to carefully unscrew and loosen the nuts.
    • This may take some extra force to loosen the nuts, and if this is case, keep in mind all safety precautions.
  2. How to Repair a Crack on a Vittorazi Moster Exhaust: passo 5, immagine 1 di 2 How to Repair a Crack on a Vittorazi Moster Exhaust: passo 5, immagine 2 di 2
    • Remove with the 10mm wrench the two nuts in the exhaust base.
  3. How to Repair a Crack on a Vittorazi Moster Exhaust: passo 6, immagine 1 di 1
    • Remove the loosen mounts and take out the exhaust with it's base.
  4. How to Repair a Crack on a Vittorazi Moster Exhaust: passo 7, immagine 1 di 1
    • Clean the cracked area with alcohol and a rug.
  5. How to Repair a Crack on a Vittorazi Moster Exhaust: passo 8, immagine 1 di 2 How to Repair a Crack on a Vittorazi Moster Exhaust: passo 8, immagine 2 di 2
    • Grind the cracked area with the grinder.
  6. How to Repair a Crack on a Vittorazi Moster Exhaust: passo 9, immagine 1 di 2 How to Repair a Crack on a Vittorazi Moster Exhaust: passo 9, immagine 2 di 2
    • Weld the cracked area with the welder.
  7. How to Repair a Crack on a Vittorazi Moster Exhaust: passo 10, immagine 1 di 2 How to Repair a Crack on a Vittorazi Moster Exhaust: passo 10, immagine 2 di 2
    • Grind the welded area with the grinder to smooth the area.
  8. How to Repair a Crack on a Vittorazi Moster Exhaust: passo 11, immagine 1 di 1
    • Reinstall the exhaust to the motor by repeating 1-3 steps in reverse order.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,067
