Salta al contenuto principale
How to Repair a Clogged Sink with Drain Snake and Liquid Drain Opener
Cosa ti serve
  1. How to Repair a Clogged Sink with Drain Snake and Liquid Drain Opener, How to Repair a Clogged Sink with Drain Snake and Liquid Drain Opener: passo 1, immagine 1 di 2 How to Repair a Clogged Sink with Drain Snake and Liquid Drain Opener, How to Repair a Clogged Sink with Drain Snake and Liquid Drain Opener: passo 1, immagine 2 di 2
    • Gather all your tools (Sink Snake, Drano or any liquid drain opener, boiled water)
  2. How to Repair a Clogged Sink with Drain Snake and Liquid Drain Opener: passo 2, immagine 1 di 3 How to Repair a Clogged Sink with Drain Snake and Liquid Drain Opener: passo 2, immagine 2 di 3 How to Repair a Clogged Sink with Drain Snake and Liquid Drain Opener: passo 2, immagine 3 di 3
    • Insert and feed the sink snake into the drain.
  3. How to Repair a Clogged Sink with Drain Snake and Liquid Drain Opener: passo 3, immagine 1 di 3 How to Repair a Clogged Sink with Drain Snake and Liquid Drain Opener: passo 3, immagine 2 di 3 How to Repair a Clogged Sink with Drain Snake and Liquid Drain Opener: passo 3, immagine 3 di 3
    • Pull the snake out of the drain to remove any debris that may be clogging the drain.
  4. How to Repair a Clogged Sink with Drain Snake and Liquid Drain Opener: passo 4, immagine 1 di 2 How to Repair a Clogged Sink with Drain Snake and Liquid Drain Opener: passo 4, immagine 2 di 2
    • Pour Drano (usually ⅓ or ½ of the bottle) into the sink and wait 15-20 minutes.
  5. How to Repair a Clogged Sink with Drain Snake and Liquid Drain Opener: passo 5, immagine 1 di 2 How to Repair a Clogged Sink with Drain Snake and Liquid Drain Opener: passo 5, immagine 2 di 2
    • Pour boiled water into the sink to flush out the Drano.
  6. How to Repair a Clogged Sink with Drain Snake and Liquid Drain Opener: passo 6, immagine 1 di 3 How to Repair a Clogged Sink with Drain Snake and Liquid Drain Opener: passo 6, immagine 2 di 3 How to Repair a Clogged Sink with Drain Snake and Liquid Drain Opener: passo 6, immagine 3 di 3
    • Open faucet and let the water run to check the clog. If the sink is still clogged, repeat steps 4-6.
Conclusione
Kylie Wong
Membro da: 02/01/24
133 Reputazione
1 Guida realizzata
UC Davis, Team 3-2, Andersen Winter 2024 Membro di UC Davis, Team 3-2, Andersen Winter 2024
UCD-ANDERSEN-W24S3G2
4 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 78
