Salta al contenuto principale
How to Repair a Broken/Cracked Soccer Shin Pad
Cosa ti serve
  1. How to Repair a Broken/Cracked Soccer Shin Pad, How to Repair a Broken/Cracked Soccer Shin Pad: passo 1, immagine 1 di 3 How to Repair a Broken/Cracked Soccer Shin Pad, How to Repair a Broken/Cracked Soccer Shin Pad: passo 1, immagine 2 di 3 How to Repair a Broken/Cracked Soccer Shin Pad, How to Repair a Broken/Cracked Soccer Shin Pad: passo 1, immagine 3 di 3
    • Start by properly cleaning the dirt off the soccer shin pad with a coarse brush.
    • Be sure to clear any dust from inside the crack as well, as any dirt left inside can interfere with the bonding agent
  2. How to Repair a Broken/Cracked Soccer Shin Pad: passo 2, immagine 1 di 1
    • Put one clamp on either side of the crack.
  3. How to Repair a Broken/Cracked Soccer Shin Pad: passo 3, immagine 1 di 1
    • Align the clamps so that there are no spaces throughout the crack.
  4. How to Repair a Broken/Cracked Soccer Shin Pad: passo 4, immagine 1 di 2 How to Repair a Broken/Cracked Soccer Shin Pad: passo 4, immagine 2 di 2
    • Make sure clamps are aligned with the crack before you apply the resin solution
    • Apply the resin solution onto the crack, being sure to fully cover the crack on both sides.
    • Let the solution dry for at least 30 minutes.
    • But we suggest leaving the shin pad out for 24 hours for best results.
  5. How to Repair a Broken/Cracked Soccer Shin Pad: passo 5, immagine 1 di 3 How to Repair a Broken/Cracked Soccer Shin Pad: passo 5, immagine 2 di 3 How to Repair a Broken/Cracked Soccer Shin Pad: passo 5, immagine 3 di 3
    • Remove the clamps slowly so that no damage will be done to the shin pad.
  6. How to Repair a Broken/Cracked Soccer Shin Pad: passo 6, immagine 1 di 2 How to Repair a Broken/Cracked Soccer Shin Pad: passo 6, immagine 2 di 2
    • Clean the extra resin solution that sits on top of the shin pad.
    • Your shin pad is now ready to use.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 296
