Salta al contenuto principale
How to Repair a Belt Loop on Dress Pants
Cosa ti serve
  1. How to Repair a Belt Loop on Dress Pants, How to Repair a Belt Loop on Dress Pants: passo 1, immagine 1 di 3 How to Repair a Belt Loop on Dress Pants, How to Repair a Belt Loop on Dress Pants: passo 1, immagine 2 di 3 How to Repair a Belt Loop on Dress Pants, How to Repair a Belt Loop on Dress Pants: passo 1, immagine 3 di 3
    • Thread the sewing machine with a thread that matches your pants.
    • Thread via your sewing machine instructions. They can be marked on your machine, or in a separate pamphlet.
  2. How to Repair a Belt Loop on Dress Pants: passo 2, immagine 1 di 3 How to Repair a Belt Loop on Dress Pants: passo 2, immagine 2 di 3 How to Repair a Belt Loop on Dress Pants: passo 2, immagine 3 di 3
    • Remove the extension table from the sewing machine.
  3. How to Repair a Belt Loop on Dress Pants: passo 3, immagine 1 di 1
    • Pin the belt loop seam side up so that the top of the loop is 1/4 inch above the seam.
  4. How to Repair a Belt Loop on Dress Pants: passo 4, immagine 1 di 3 How to Repair a Belt Loop on Dress Pants: passo 4, immagine 2 di 3 How to Repair a Belt Loop on Dress Pants: passo 4, immagine 3 di 3
    • Sew using a straight stitch along the seam.
    • Use the reverse feature on the sewing machine to go over the stitches three times.
    • Once the sewing foot is down and the needle is in the fabric you can remove the pin.
  5. How to Repair a Belt Loop on Dress Pants: passo 5, immagine 1 di 3 How to Repair a Belt Loop on Dress Pants: passo 5, immagine 2 di 3 How to Repair a Belt Loop on Dress Pants: passo 5, immagine 3 di 3
    • Remove the pants from the sewing machine by cutting the threads.
  6. How to Repair a Belt Loop on Dress Pants: passo 6, immagine 1 di 1
    • Fold the interfacing over so that it is out of the way of the needle.
    • If the pants do not have interfacing, this step can be skipped.
  7. How to Repair a Belt Loop on Dress Pants: passo 7, immagine 1 di 2 How to Repair a Belt Loop on Dress Pants: passo 7, immagine 2 di 2
    • Sew the belt loop a 1/4 inch below the seam using a straight stitch.
    • Use the reverse feature to go over the stitches three times.
  8. How to Repair a Belt Loop on Dress Pants: passo 8, immagine 1 di 1
  9. How to Repair a Belt Loop on Dress Pants: passo 9, immagine 1 di 1
    • Fold the belt loop over.
  10. How to Repair a Belt Loop on Dress Pants: passo 10, immagine 1 di 3 How to Repair a Belt Loop on Dress Pants: passo 10, immagine 2 di 3 How to Repair a Belt Loop on Dress Pants: passo 10, immagine 3 di 3
    • Trim the belt loop's excess length so that there is a 1/4 inch overlap.
  11. How to Repair a Belt Loop on Dress Pants: passo 11, immagine 1 di 1
    • Pin the folded belt loop to the top of the waistband.
  12. How to Repair a Belt Loop on Dress Pants: passo 12, immagine 1 di 2 How to Repair a Belt Loop on Dress Pants: passo 12, immagine 2 di 2
    • Sew the top of the belt loop with an 1/8 inch seam allowance, using a straight stitch.
    • Use the reverse feature on the sewing machine and go over the stitches three times.
  13. How to Repair a Belt Loop on Dress Pants: passo 13, immagine 1 di 3 How to Repair a Belt Loop on Dress Pants: passo 13, immagine 2 di 3 How to Repair a Belt Loop on Dress Pants: passo 13, immagine 3 di 3
  14. How to Repair a Belt Loop on Dress Pants: passo 14, immagine 1 di 1
    • Trim any remaining threads.
Linea Traguardo
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 26
Tutti i Tempi: 476
