Salta al contenuto principale
How to Repair a Bed Rail
Cosa ti serve
  1. How to Repair a Bed Rail, How to Repair a Bed Rail: passo 1, immagine 1 di 1
    • Place an item(s) underneath the bed rail to support it. This can be bricks or books.
  2. How to Repair a Bed Rail: passo 2, immagine 1 di 1
    • Measure the length of the slat, and mark the middle.
    • This is the position where you will place the wooden plank and hammer in the nails.
  3. How to Repair a Bed Rail: passo 3, immagine 1 di 2 How to Repair a Bed Rail: passo 3, immagine 2 di 2
    • Vertically place your pre-cut wooden plank under the slat that is detached.
  4. How to Repair a Bed Rail: passo 4, immagine 1 di 1
    • Hammer the 50 mm nails down into the slat and into the wooden plank. You can use 2 or more to ensure the wooden plank is secure.
  5. How to Repair a Bed Rail: passo 5, immagine 1 di 1
    • Afterwards, run the glue along the detached bed rail.
  6. How to Repair a Bed Rail: passo 6, immagine 1 di 1
    • Reattach the bed rail and let the glue dry.
  7. How to Repair a Bed Rail: passo 7, immagine 1 di 1
    • After the glue has dried, remove your supports.
Conclusione
Endiyah Franklin
Membro da: 03/31/20
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 42
Tutti i Tempi: 2,182
