Salta al contenuto principale
How to Repair a Backward-Tilted Porch Swing
Cosa ti serve
  1. How to Repair a Backward-Tilted Porch Swing, How to Repair a Backward-Tilted Porch Swing: passo 1, immagine 1 di 2 How to Repair a Backward-Tilted Porch Swing, How to Repair a Backward-Tilted Porch Swing: passo 1, immagine 2 di 2
    • (Before) Backward-Tilted Swing
    • Examine each side of the swing to determine the hook type used for hanging (ex., S-hook, eye bolt, screw carabiner hook, or other types).
    • For this example, the hook is an S hook.
    Chiedi a FixBot
    Aggiungi Commento
  2. How to Repair a Backward-Tilted Porch Swing: passo 2, immagine 1 di 3 How to Repair a Backward-Tilted Porch Swing: passo 2, immagine 2 di 3 How to Repair a Backward-Tilted Porch Swing: passo 2, immagine 3 di 3
    • Use a measuring tape to check and record the height of the swing from the ground to the armrest. Repeat this step on the other side.
    • Use a measuring tape to check and record the height of the swing from the ground to the top of the swing. Repeat this step on the other side.
    • Record these measurements to compare later.
    • (Optional) Place a level on the seat of the swing to check if it is level. Adjust the chains as needed until the bubble is centered.
    • Notice how the bubble is not centered to show the swing is level.
    Chiedi a FixBot
    Aggiungi Commento
  3. How to Repair a Backward-Tilted Porch Swing: passo 3, immagine 1 di 2 How to Repair a Backward-Tilted Porch Swing: passo 3, immagine 2 di 2
    • Use one pair of pliers to hold the S-hook steady.
    • Use the second pair of pliers to gently open the bottom side of the hook, allowing the chain links to slide off. This provides better leverage and stability.
    • For other hook types, gently open or unscrew the hook and slide the chain off without bending or damaging the hook.
    • Use caution when opening the hook to avoid injury from any sharp edges.
    • Repeat this step to open the hook on the other side of the swing.
    • There should be a noticeable difference in the openings at the top and bottom of the hook.
    Chiedi a FixBot
    Aggiungi Commento
  4. How to Repair a Backward-Tilted Porch Swing: passo 4, immagine 1 di 2 How to Repair a Backward-Tilted Porch Swing: passo 4, immagine 2 di 2
    • Slide the chain closest to the back of the swing off the hook after opening it.
    • Other types of hooks may require different methods, but most of them should allow the chain to gently slide off.
    • Measure each link until you reach your desired position.
    • On the other side, use a marker or pencil to mark the link of the chain that will be reattached on the other side.
    • If your swing is already level horizontally, the number of links removed should match on each side.
    Chiedi a FixBot
    Aggiungi Commento
  5. How to Repair a Backward-Tilted Porch Swing: passo 5, immagine 1 di 1
    • Reattach each chain to its hook.
    • Ensure that the marked link is connected to the hook on both sides.
    • Ensure that you have a firm grip on the chain to prevent it from dropping. Dropping the swing can cause injury or damage.
    • Ensure that the swing is at the desired height.
    Chiedi a FixBot
    Aggiungi Commento
  6. How to Repair a Backward-Tilted Porch Swing: passo 6, immagine 1 di 3 How to Repair a Backward-Tilted Porch Swing: passo 6, immagine 2 di 3 How to Repair a Backward-Tilted Porch Swing: passo 6, immagine 3 di 3
    • Compare previous measurements to new measurements to ensure they are consistent on both sides. This is crucial to a level swing.
    • (Optional) Place a level on the armrest of the swing to check if it is level.
    • The bubbles are resting between the two lines, indicating that the swing is level.
    • (Optional) If there are still excess links, use bolt cutters to snip them off. Repeat this on both sides, if necessary.
    • Be careful when using bolt cutters to prevent injury.
    Chiedi a FixBot
    Aggiungi Commento
  7. How to Repair a Backward-Tilted Porch Swing: passo 7, immagine 1 di 1
    • Use pliers to gently squeeze the opening of the S-hook closed to secure the chain in place.
    • Other hooks may not require pliers to tighten the hook.
    • Be cautious not to apply too much pressure, as this could bend the hook or damage the chain.
    Chiedi a FixBot
    Aggiungi Commento
  8. How to Repair a Backward-Tilted Porch Swing: passo 8, immagine 1 di 1
    • Give the swing a gentle push to ensure that it swings freely and is stable after adjustments on both sides.
    • (After) Level Swing
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Test your swing out by sitting in it. If the swing is still not in the desired position, repeat these steps to reposition it. Remember to check your swing regularly to keep it in good working condition!
Hannah Myrick
Membro da: 03/19/24
157 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 20
Ultimi 30 giorni: 88
Tutti i Tempi: 511
