Salta al contenuto principale
How to Repair Your Torn Sleeping Bag
Cosa ti serve
  1. How to Repair Your Torn  Sleeping Bag, How to Repair Your Torn  Sleeping Bag: passo 1, immagine 1 di 1
    • Push any stuffing/down filling back into the hole.
    • You can use your finger, but depending on the size of the hole you may want to use a smaller object so that it doesn't tear further.
  2. How to Repair Your Torn  Sleeping Bag: passo 2, immagine 1 di 3 How to Repair Your Torn  Sleeping Bag: passo 2, immagine 2 di 3 How to Repair Your Torn  Sleeping Bag: passo 2, immagine 3 di 3
    • Take your roll of duct tape and cut off a small amount (about as long as the tear)
  3. How to Repair Your Torn  Sleeping Bag: passo 3, immagine 1 di 1
    • Fold the edges of the tear back towards the stuffing so that you create a clean edge with no fraying.
    • This makes it easier to apply the duct tape.
  4. How to Repair Your Torn  Sleeping Bag: passo 4, immagine 1 di 1
    • Apply the duct tape to each half of the tear and fold it under, creating a cuff/edge of duct tape
    • This will allow you to sew the fabric without tearing it.
  5. How to Repair Your Torn  Sleeping Bag: passo 5, immagine 1 di 1
    • Take a small needle and thread it with thread of similar color to the sleeping bag material (can be any color but a similar one makes the fix less noticeable)
    • Working with needles can be dangerous.
  6. How to Repair Your Torn  Sleeping Bag: passo 6, immagine 1 di 3 How to Repair Your Torn  Sleeping Bag: passo 6, immagine 2 di 3 How to Repair Your Torn  Sleeping Bag: passo 6, immagine 3 di 3
    • Push the two pieces of duct tape together and use the needle and thread to sew them together with a whip stitch.
  7. How to Repair Your Torn  Sleeping Bag: passo 7, immagine 1 di 3 How to Repair Your Torn  Sleeping Bag: passo 7, immagine 2 di 3 How to Repair Your Torn  Sleeping Bag: passo 7, immagine 3 di 3
    • Pull the thread tight when you reach the end of the tape and tie a knot in the string
    • Cut off any remaining thread.
  8. How to Repair Your Torn  Sleeping Bag: passo 8, immagine 1 di 2 How to Repair Your Torn  Sleeping Bag: passo 8, immagine 2 di 2
    • Cut off any remaining duct tape.
    • Be wary of a sticky residue that may be left behind from the duct tape if pulled off to remove excess
    • Enjoy your newly patched sleeping bag!
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 10-4, Green Fall 2015 Membro di Cal Poly, Team 10-4, Green Fall 2015
CPSU-GREEN-F15S10G4
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 6,407
