Salta al contenuto principale
How to Repair Trim On a Decorative Towel
Cosa ti serve
  1. How to Repair Trim On a Decorative Towel, How to Repair Trim On a Decorative Towel: passo 1, immagine 1 di 1
    • Choose a thread the same colour as the towel.
    • Use sewing scissors to cut a piece of thread about 18 inches long.
  2. How to Repair Trim On a Decorative Towel: passo 2, immagine 1 di 1
    • Thread the string through the needle.
    • Tie a knot at the longest end of the thread.
  3. How to Repair Trim On a Decorative Towel: passo 3, immagine 1 di 2 How to Repair Trim On a Decorative Towel: passo 3, immagine 2 di 2
    • Flip your towel over so the backside of the towel is facing up.
  4. How to Repair Trim On a Decorative Towel: passo 4, immagine 1 di 2 How to Repair Trim On a Decorative Towel: passo 4, immagine 2 di 2
    • Starting at one side of the rip, insert the needle through the trim and then the towel.
    • Pull the thread through until it stops at the knot.
  5. How to Repair Trim On a Decorative Towel: passo 5, immagine 1 di 2 How to Repair Trim On a Decorative Towel: passo 5, immagine 2 di 2
    • Flip the towel over so the front side is facing up.
    • Insert the needle through the towel, then the trim.
    • Pull the thread through.
  6. How to Repair Trim On a Decorative Towel: passo 6, immagine 1 di 2 How to Repair Trim On a Decorative Towel: passo 6, immagine 2 di 2
    • Repeat steps 4 and 5 until you reach the end of the trim.
  7. How to Repair Trim On a Decorative Towel: passo 7, immagine 1 di 3 How to Repair Trim On a Decorative Towel: passo 7, immagine 2 di 3 How to Repair Trim On a Decorative Towel: passo 7, immagine 3 di 3
    • Insert the needle through the back of the towel.
    • Pull the string through with enough length to create a small loop.
    • Put the needle through the loop and pull the string to tie a knot.
  8. How to Repair Trim On a Decorative Towel: passo 8, immagine 1 di 2 How to Repair Trim On a Decorative Towel: passo 8, immagine 2 di 2
    • Remove the needle.
    • Use your sewing scissors to cut the remaining thread.
Conclusione
Victoria Torkos
Membro da: 09/19/22
157 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 254
