Salta al contenuto principale
How to Repair Molded Baseboards
Cosa ti serve
  1. How to Repair Molded Baseboards, How to Repair Molded Baseboards: passo 1, immagine 1 di 1
    • Sand the damaged area with the 120 grit sandpaper or a sanding block.
    • Use a utility knife to smooth rougher areas if needed.
  2. How to Repair Molded Baseboards: passo 2, immagine 1 di 1
    • Lightly coat the damaged area with wood glue.
  3. How to Repair Molded Baseboards: passo 3, immagine 1 di 2 How to Repair Molded Baseboards: passo 3, immagine 2 di 2
    • Build up the affected areas with the wood filler. This can be applied with your hands (as individual product safety allows), a spare piece of cardboard, or a popsicle stick.
    • Allow to dry a few hours or overnight (based on product directions).
  4. How to Repair Molded Baseboards: passo 4, immagine 1 di 1
    • Cut or fold the 150 grit sandpaper sheet into various pieces to allow proper fit into the various grooves of your baseboard.
  5. How to Repair Molded Baseboards: passo 5, immagine 1 di 1
    • Sand the dried wood filler with 150 grit sandpaper.
    • Start from the inside of the baseboard and move out toward the repaired area.
    • Avoid a sawing or back-and-forth motion with the sandpaper to achieve a smooth finish.
  6. How to Repair Molded Baseboards: passo 6, immagine 1 di 1
    • Wipe with a slightly damp cloth.
    • Repeat step 3 as needed.
    • Wait at least one hour.
    • Repeat step 6 for the final sanding.
  7. How to Repair Molded Baseboards: passo 7, immagine 1 di 1
    • Touch-up with matching paint as needed.
Conclusione
Clean-up should be a breeze, and you should be ready to finish your weekend with loads of time to spare after this simple project!
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 17
Ultimi 7 Giorni: 68
Ultimi 30 Giorni: 320
Tutti i Tempi: 7,791
