Salta al contenuto principale
How to Repair Malfunctioning Window Blinds
Cosa ti serve
  1. How to Repair Malfunctioning Window Blinds, How to Repair Malfunctioning Window Blinds: passo 1, immagine 1 di 3 How to Repair Malfunctioning Window Blinds, How to Repair Malfunctioning Window Blinds: passo 1, immagine 2 di 3 How to Repair Malfunctioning Window Blinds, How to Repair Malfunctioning Window Blinds: passo 1, immagine 3 di 3
    • Remove the clips that keep the blinds attached to the wall.
    • These should easily slide out.
  2. How to Repair Malfunctioning Window Blinds: passo 2, immagine 1 di 2 How to Repair Malfunctioning Window Blinds: passo 2, immagine 2 di 2
    • Slide the angling rod off its hook.
  3. How to Repair Malfunctioning Window Blinds: passo 3, immagine 1 di 1
    • Locate the pulley where the string exits the top housing.
    • The string has likely fallen off of the pulley, causing too much resistance for the retraction mechanism to work properly.
  4. How to Repair Malfunctioning Window Blinds: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Pull the shaft partially out of the housing.
    • The shaft is not supposed to come out of the housing all of the way. This step is meant to bend the shaft just enough so that the tweezers can reach behind it.
  5. How to Repair Malfunctioning Window Blinds: passo 5, immagine 1 di 1
    • From the bottom of the housing, pull on the string that runs through the blinds.
    • This step is meant to add slack in the string.
    • Hold the slack by putting a finger through the loop it makes.
  6. How to Repair Malfunctioning Window Blinds: passo 6, immagine 1 di 1
    • While holding the slack with your middle finger, and the shaft with your index finger, use the tweezers to grab on to the string from the top side of the housing.
    • Pull the string up and toward you as you remove your middle finger from the loop.
  7. How to Repair Malfunctioning Window Blinds: passo 7, immagine 1 di 2 How to Repair Malfunctioning Window Blinds: passo 7, immagine 2 di 2
    • Test the blinds to see if they are working. If they aren't, check to see if the string has been realigned on the pulley and repeat the steps as necessary.
Conclusione
Enjoy your retractable blinds!
Adam Porter
Membro da: 02/26/22
145 Reputazione
1 Guida realizzata
2Commenti sulla guida
Cordless. This is not a cordless shade. Try again.
Joseph Gallien - Replica
These aren't instructions for CORDLESS but I wasn't able to find any. I was able to repair the broken cord of my cordless blind; it took a couple hours but it's as good as new. Surprisingly, the tension cord for both sides is actually one continual cord. You'd want to replace both sides if yours is different. Nylon Cord 1.4mm worked for me. It does help if you have another blind to use as a guide on how to thread the pulleys especially if both sides break (which happened to me). Maybe I'll make a video on my next broken cord. Hint: When you measure the length of the cord, add extra feet before you cut the new cord.
Dwayne Miller - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 54
Ultimi 30 Giorni: 256
Tutti i Tempi: 35,262
