Salta al contenuto principale
How to Repair Arm Gapes
Cosa ti serve
  1. How to Repair Arm Gapes, How to Repair Arm Gapes: passo 1, immagine 1 di 1
    • Gather the supplies needed.
  2. How to Repair Arm Gapes: passo 2, immagine 1 di 2 How to Repair Arm Gapes: passo 2, immagine 2 di 2
    • Grab your measuring tape.
    • Measure from the middle of the breast to the under arm part.
  3. How to Repair Arm Gapes: passo 3, immagine 1 di 3 How to Repair Arm Gapes: passo 3, immagine 2 di 3 How to Repair Arm Gapes: passo 3, immagine 3 di 3
    • Mark the middle of the breast and at the end where the under arm is. (Slide one and two)
    • Mark how big you want to close the gape. (Depends on how big your armhole gape is) (Slide three)
    • Mine was about 0.5 inches. (Slide three)
  4. How to Repair Arm Gapes: passo 4, immagine 1 di 3 How to Repair Arm Gapes: passo 4, immagine 2 di 3 How to Repair Arm Gapes: passo 4, immagine 3 di 3
    • Connect both of the dots from the breast to the two dots you marked near the underarm.
    • Fold the second line you created and pin them to keep it coming from getting undone. (Slides two and three)
  5. How to Repair Arm Gapes: passo 5, immagine 1 di 1
    • Sew across.
    • I used a straight sew stitch by hand (you can use a sewing machine and any stitch)
  6. How to Repair Arm Gapes: passo 6, immagine 1 di 1
    • Lastly, cut the access off.
    • Then flip it inside out.
    • And your done!
Conclusione
Thank you for taking the time to read this.
Danielle Fontanos
Membro da: 10/23/23
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 115
