Ricambi
Nessuna parte specificata.
Panoramica Video
As you can see from the photo, the negative pole of the battery is connected to the main board through the aluminum body of the keyboard.
There are two contact areas:
Between the battery cover and the KB aluminum body
Between the power button assemble and the KB aluminum body
If the device has a power problem, we need to check and clean these two places
Use a Coin to remove the metal battery screw cover
Change the batteries (AA) and test the keyboard
If the keyboard does not work, go to the next step
Use cotton buds, Toothpicks and Isopropyl Alcohol to clean the contact area and the battery cap.
Test the device and f the keyboard does not work, go to the next step
Remove the plastic cap from the middle on the tube and disconnect the KB flex cable
There are a screw secured the BT antenna, remove it
Slide the board out.
Altre 4 persone hanno completato questa guida.
Un commento
Add a little dielectric grease to the battery end cap. Had considerable corrosion despite batteries not leaking. Strange design.
