Salta al contenuto principale
How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter
Cosa ti serve
  1. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter, Air Filter: passo 1, immagine 1 di 2 How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter, Air Filter: passo 1, immagine 2 di 2
    • Make sure that the motor is off and has had time to cool after being used.
    • Push in the clips on the top of the cover, and remove the cover.
  2. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: passo 2, immagine 1 di 1
    • Make a note of the position of the filter, and remove the cover.
  3. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: passo 3, immagine 1 di 1
    • Lightly bend the filter so that you can see all surfaces of the filter.
  4. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: passo 4, immagine 1 di 1
    • Use compressed air to blow out dirt or dust particles from the air filter.
    • You can bend it in several places to make sure you clean between each of the fins.
  5. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: passo 5, immagine 1 di 1
    • Seat the filter in the same position you made a note of in Step 2.
    • If the filter is still bent from cleaning it, lightly bend it in the opposite direction so that it can lay flat in your hand.
    • Place the cover onto the air filter. This shouldn't require any force, so the filter may need to be readjusted if it does require force.
  6. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: passo 6, immagine 1 di 2 How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: passo 6, immagine 2 di 2
    • Push the clips of the cover in until they click.
    • Check to make sure that the cover is secure, and there are no gaps for dirt or dust to get in.
Linea Traguardo
Pearce McKee
Membro da: 03/31/20
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 57
Tutti i Tempi: 1,311
