Salta al contenuto principale
How to Remove the Scratches from an Acrylic Watch Face
Cosa ti serve
  1. How to Remove the Scratches from an Acrylic Watch Face, How to Remove the Scratches from an Acrylic Watch Face: passo 1, immagine 1 di 2 How to Remove the Scratches from an Acrylic Watch Face, How to Remove the Scratches from an Acrylic Watch Face: passo 1, immagine 2 di 2
    • Examine the damage and identify the boundaries for buffing the face of the watch.
    • Working with sandpaper can damage other areas of the watch, so understanding your working area will prevent any careless mistakes.
  2. How to Remove the Scratches from an Acrylic Watch Face: passo 2, immagine 1 di 3 How to Remove the Scratches from an Acrylic Watch Face: passo 2, immagine 2 di 3 How to Remove the Scratches from an Acrylic Watch Face: passo 2, immagine 3 di 3
    • Wipe the watch surface with a paper towel dampened with isopropyl alcohol.
    • It is important to clean the watch of any surface debris to prevent making new scratches.
  3. How to Remove the Scratches from an Acrylic Watch Face: passo 3, immagine 1 di 3 How to Remove the Scratches from an Acrylic Watch Face: passo 3, immagine 2 di 3 How to Remove the Scratches from an Acrylic Watch Face: passo 3, immagine 3 di 3
    • Use the 1000-grit sandpaper, and gently sand the face of the watch in a circular motion.
    • This step is to remove any deep scratches.
  4. How to Remove the Scratches from an Acrylic Watch Face: passo 4, immagine 1 di 3 How to Remove the Scratches from an Acrylic Watch Face: passo 4, immagine 2 di 3 How to Remove the Scratches from an Acrylic Watch Face: passo 4, immagine 3 di 3
    • With your fingernail, feel the surface of the watch for any remaining deep scratches.
    • Keep sanding until you no longer feel scratches.
  5. How to Remove the Scratches from an Acrylic Watch Face: passo 5, immagine 1 di 2 How to Remove the Scratches from an Acrylic Watch Face: passo 5, immagine 2 di 2
    • Clean the surface again with a paper towel and isopropyl alcohol to prep the watch face for polishing.
  6. How to Remove the Scratches from an Acrylic Watch Face: passo 6, immagine 1 di 2 How to Remove the Scratches from an Acrylic Watch Face: passo 6, immagine 2 di 2
    • With the tube of polyWatch, place a small dab of the polishing compound on the face of the watch.
  7. How to Remove the Scratches from an Acrylic Watch Face: passo 7, immagine 1 di 3 How to Remove the Scratches from an Acrylic Watch Face: passo 7, immagine 2 di 3 How to Remove the Scratches from an Acrylic Watch Face: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Microfiber Cleaning Cloths
    $3.99
    • With the microfiber cloth, begin working on the face of the watch in a circular motion for at least 2-3 minutes.
    • Wipe away any excess compound with a clean cloth and examine your results.
  8. How to Remove the Scratches from an Acrylic Watch Face: passo 8, immagine 1 di 2 How to Remove the Scratches from an Acrylic Watch Face: passo 8, immagine 2 di 2
    • Repeat the process until you are satisfied with the results.
Conclusione
Now, your watch should look close to the day you bought it!
Lloyd Derryk Alba
Membro da: 09/20/23
157 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 61
Tutti i Tempi: 1,662
