Salta al contenuto principale
How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation)
Cosa ti serve
  1. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation), How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 1, immagine 1 di 2 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation), How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 1, immagine 2 di 2
    • On the top of the printer, turn the injector counter-clockwise and pull the tab.
  2. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 2, immagine 1 di 3 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 2, immagine 2 di 3 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 2, immagine 3 di 3
    • Insert your fingers in the center of the filament cartridge and slowly pull it away from the printer.
  3. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 3, immagine 1 di 1
    • Place the cartridge face up and pry off the lid of the cartridge.
  4. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 4, immagine 1 di 2 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 4, immagine 2 di 2
    • Gently flip the cartridge on its front and remove the two 2mm Hex screws using a Hex key.
  5. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 5, immagine 1 di 1
    • Flip the cartridge face up and remove the gearbox and extractor tube.
  6. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 6, immagine 1 di 3 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 6, immagine 2 di 3 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 6, immagine 3 di 3
    • Place your thumb on the front of the injector head and your middle finger on the needle.
    • Firmly pull the needle towards your thumb until the injector head cases cracks and pulls apart the case.
  7. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 7, immagine 1 di 2 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 7, immagine 2 di 2
    • Heat the needle using a lighter, making sure that the flame does not touch the needle.
    • Using needle-nose pliers, pull the needle from the tube.
    • Do not touch the needle as it may still be hot.
  8. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 8, immagine 1 di 1
    • Insert a paper clip and turn until the clog is removed.
Conclusione
Hector Vazquez
Membro da: 10/23/20
157 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 15
Tutti i Tempi: 514
