Salta al contenuto principale
How to Remove a Broken and Embedded Screw
Cosa ti serve
  1. How to Remove a Broken and Embedded Screw, How to Remove a Broken and Embedded Screw: passo 1, immagine 1 di 1
    • Use an angle grinder to grind the tip of the broken screw until its surface is smooth and even.
  2. How to Remove a Broken and Embedded Screw: passo 2, immagine 1 di 2 How to Remove a Broken and Embedded Screw: passo 2, immagine 2 di 2
    • Place a center punch in the middle of the tip of the screw.
    • Use a hammer to hit the center punch to make a dent in the center of the embedded screw.
  3. How to Remove a Broken and Embedded Screw: passo 3, immagine 1 di 3 How to Remove a Broken and Embedded Screw: passo 3, immagine 2 di 3 How to Remove a Broken and Embedded Screw: passo 3, immagine 3 di 3
    • Place a center drill bit in the dent made in the previous step and start drilling until it expands enough to fit the standard drill bit inside it.
    • Always keep the drill bit at a 90 degree angle to the surface of the screw since tilting it can bend and break its tip.
  4. How to Remove a Broken and Embedded Screw: passo 4, immagine 1 di 3 How to Remove a Broken and Embedded Screw: passo 4, immagine 2 di 3 How to Remove a Broken and Embedded Screw: passo 4, immagine 3 di 3
    • Make a hole in the tip of the screw by drilling with a standard drill bit.
    • Keep drilling until the hole reaches near the end of the screw.
  5. How to Remove a Broken and Embedded Screw: passo 5, immagine 1 di 2 How to Remove a Broken and Embedded Screw: passo 5, immagine 2 di 2
    • Insert a screw extractor in the hole and then hammer it inside, making sure it is tight.
  6. How to Remove a Broken and Embedded Screw: passo 6, immagine 1 di 3 How to Remove a Broken and Embedded Screw: passo 6, immagine 2 di 3 How to Remove a Broken and Embedded Screw: passo 6, immagine 3 di 3
    • Using a wrench, unscrew the extractor.
    • The screw will come along with it, freeing the hole.
  7. How to Remove a Broken and Embedded Screw: passo 7, immagine 1 di 2 How to Remove a Broken and Embedded Screw: passo 7, immagine 2 di 2
    • Screw the new screw inside the freed hole.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 123
Ultimi 30 Giorni: 469
Tutti i Tempi: 6,679
