Salta al contenuto principale
How to Remove Rust from the Nipper D-108
Cosa ti serve
  1. How to Remove Rust from the Nipper D-108, How to Remove Rust from the Nipper D-108: passo 1, immagine 1 di 3 How to Remove Rust from the Nipper D-108, How to Remove Rust from the Nipper D-108: passo 1, immagine 2 di 3 How to Remove Rust from the Nipper D-108, How to Remove Rust from the Nipper D-108: passo 1, immagine 3 di 3
    • Take out a medium bowl.
    • Put on a pair of nitrile gloves.
  2. How to Remove Rust from the Nipper D-108: passo 2, immagine 1 di 3 How to Remove Rust from the Nipper D-108: passo 2, immagine 2 di 3 How to Remove Rust from the Nipper D-108: passo 2, immagine 3 di 3
    • Pour about 3-4 tablespoons of baking soda into the bowl.
    • Pour enough white vinegar into the bowl to cover the nipper.
    • Mix baking soda and white vinegar together.
  3. How to Remove Rust from the Nipper D-108: passo 3, immagine 1 di 2 How to Remove Rust from the Nipper D-108: passo 3, immagine 2 di 2
    • Put the nipper in the mixture and soak for about an hour.
  4. How to Remove Rust from the Nipper D-108: passo 4, immagine 1 di 3 How to Remove Rust from the Nipper D-108: passo 4, immagine 2 di 3 How to Remove Rust from the Nipper D-108: passo 4, immagine 3 di 3
    • Take a toothbrush and dip it in the mixture of vinegar and baking soda.
    • Scrub the rusty areas of the nipper until it is clean.
  5. How to Remove Rust from the Nipper D-108: passo 5, immagine 1 di 1
    • Wash the nipper with water.
  6. How to Remove Rust from the Nipper D-108: passo 6, immagine 1 di 1
    • Use a towel to wipe the nipper dry.
Conclusione
Vi Phan
Membro da: 07/03/22
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 46
Tutti i Tempi: 1,221
