Salta al contenuto principale
How to Remove Rust from a Gardening Shovel
Cosa ti serve
  1. How to Remove Rust from a Gardening Shovel, How to Remove Rust from a Gardening Shovel: passo 1, immagine 1 di 1
    • Fill a large container with water.
  2. How to Remove Rust from a Gardening Shovel: passo 2, immagine 1 di 1
    • Add an ample amount of distilled white vinegar.
  3. How to Remove Rust from a Gardening Shovel: passo 3, immagine 1 di 1
    • Soak the shovel for at least 10 minutes, but ideally for 24 hours.
  4. How to Remove Rust from a Gardening Shovel: passo 4, immagine 1 di 1
    • Scrub the shovel with a scrub brush.
    • Scrub with a tooth brush.
    • Scrub with a Brillo pad.
  5. How to Remove Rust from a Gardening Shovel: passo 5, immagine 1 di 1
    • Refill the large container with fresh water.
  6. How to Remove Rust from a Gardening Shovel: passo 6, immagine 1 di 1
    • Add 1-2 cups of baking soda.
  7. How to Remove Rust from a Gardening Shovel: passo 7, immagine 1 di 1
    • Soak the shovel for 15 minutes.
  8. How to Remove Rust from a Gardening Shovel: passo 8, immagine 1 di 1
    • Rinse the shovel.
  9. How to Remove Rust from a Gardening Shovel: passo 9, immagine 1 di 1
    • Dry the shovel completely.
  10. How to Remove Rust from a Gardening Shovel: passo 10, immagine 1 di 1
    • Oil the shovel with coconut oil.
Conclusione
Repeat process until rust is completely removed.
Brigette B
Membro da: 09/22/23
181 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 91
