Salta al contenuto principale
How to Remove Makeup Stain from Shirt
Cosa ti serve
  1. How to Remove Makeup Stain from Shirt, How to Remove Makeup Stain from Shirt: passo 1, immagine 1 di 1
    • Place a white napkin or rag under the shirt to avoid making a mess or colour transfer into the garment.
  2. How to Remove Makeup Stain from Shirt: passo 2, immagine 1 di 2 How to Remove Makeup Stain from Shirt: passo 2, immagine 2 di 2
    • Pour micellar water over the stain
    • Micellar water can be replaced by any kind of water-based makeup remover.
    • Do not use an oil-based makeup remover as it will permanently damage the shirt.
  3. How to Remove Makeup Stain from Shirt: passo 3, immagine 1 di 2 How to Remove Makeup Stain from Shirt: passo 3, immagine 2 di 2
    • Pat the stain dry with the napkin/rag from Step 1.
    • Do not use Kleenex tissues as they will fall apart and make a mess by sticking to the fabric.
  4. How to Remove Makeup Stain from Shirt: passo 4, immagine 1 di 1
    • Wash the shirt in cold water with the detergent of your choice.
  5. How to Remove Makeup Stain from Shirt: passo 5, immagine 1 di 1
    • Pour detergent over the stain. Pour baking soda or powder over the soap.
    • The recommended measurement is 1/4 of a teaspoon of baking soda/powder but you may use more if the stain is larger.
  6. How to Remove Makeup Stain from Shirt: passo 6, immagine 1 di 1
    • Scrub the paste into the shirt with a toothbrush.
  7. How to Remove Makeup Stain from Shirt: passo 7, immagine 1 di 1
    • Let rest for 15 minutes.
  8. How to Remove Makeup Stain from Shirt: passo 8, immagine 1 di 1
    • Wash the shirt in cold water followed by lukewarm water.
  9. How to Remove Makeup Stain from Shirt: passo 9, immagine 1 di 1
    • Let the shirt air dry and iron it if necessary.
Conclusione
Let the shirt air dry and iron as needed.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 26
Tutti i Tempi: 336
