Salta al contenuto principale
How to Remove Hard Wax from a Wax Warmer
Cosa ti serve
  1. How to Remove Hard Wax from a Wax Warmer, How to Remove Hard Wax from a Wax Warmer: passo 1, immagine 1 di 2 How to Remove Hard Wax from a Wax Warmer, How to Remove Hard Wax from a Wax Warmer: passo 1, immagine 2 di 2
    • Plug in your wax warmer.
  2. How to Remove Hard Wax from a Wax Warmer: passo 2, immagine 1 di 1
    • Turn up the heat nozzle to the maximum temperature.
  3. How to Remove Hard Wax from a Wax Warmer: passo 3, immagine 1 di 1
    • Allow the wax to sit for a few minutes until fully melted.
  4. How to Remove Hard Wax from a Wax Warmer: passo 4, immagine 1 di 2 How to Remove Hard Wax from a Wax Warmer: passo 4, immagine 2 di 2
    • Take a paper towel and popsicle stick and wipe up as much of the wax as you can.
  5. How to Remove Hard Wax from a Wax Warmer: passo 5, immagine 1 di 2 How to Remove Hard Wax from a Wax Warmer: passo 5, immagine 2 di 2
    • Add a tablespoon of your oil of choice to the wax bowl (suggestions: coconut oil or olive oil) and swish it around the bowl.
  6. How to Remove Hard Wax from a Wax Warmer: passo 6, immagine 1 di 2 How to Remove Hard Wax from a Wax Warmer: passo 6, immagine 2 di 2
    • Use another paper towel and popsicle stick to clean up the remaining residue.
  7. How to Remove Hard Wax from a Wax Warmer: passo 7, immagine 1 di 2 How to Remove Hard Wax from a Wax Warmer: passo 7, immagine 2 di 2
    • Turn off the wax warmer and unplug it from electrical socket.
  8. How to Remove Hard Wax from a Wax Warmer: passo 8, immagine 1 di 1
    • Once the wax warmer is cool, proceed to wipe up any excess oil with a paper towel.
Linea Traguardo
MaCara Woods
Membro da: 08/22/23
157 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 76
