Salta al contenuto principale
How to Recharge the A/C in a 2012 Hyundai Tucson
Cosa ti serve
    1. How to Recharge the A/C in a 2012 Hyundai Tucson, How to Recharge the A/C in a 2012 Hyundai Tucson: passo 1, immagine 1 di 1
      • Enter the car and turn on the coldest and most powerful A/C you can.
      • Make sure the A/C button is on.
      Chiedi a FixBot
      Aggiungi Commento
    2. How to Recharge the A/C in a 2012 Hyundai Tucson: passo 2, immagine 1 di 1
      • Pop the hood open on the left side of the driver’s seat.
      • Secure the hood with the pole brace found on the left side of the engine near the low pressure fill port.
      Chiedi a FixBot
      Aggiungi Commento
    3. How to Recharge the A/C in a 2012 Hyundai Tucson: passo 3, immagine 1 di 2 How to Recharge the A/C in a 2012 Hyundai Tucson: passo 3, immagine 2 di 2
      • Screw the hose to the top of the R134a refrigerant. Screw to the right until failure. Remove low pressure fill cap.
      Chiedi a FixBot
      Aggiungi Commento
    4. How to Recharge the A/C in a 2012 Hyundai Tucson: passo 4, immagine 1 di 2 How to Recharge the A/C in a 2012 Hyundai Tucson: passo 4, immagine 2 di 2
      • With the A/C blowing cold and strong, attach the adapter at the end of the hose to the low pressure fill port.
      • Once the adapter is securely fastened, pull and hold the trigger with the bottle upside down.
      • You will begin to feel the bottle get cold. This is the refrigerant becoming activated.
      Chiedi a FixBot
      Aggiungi Commento
Linea Traguardo
Micah B
Membro da: 03/21/23
109 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 7
Ultimi 7 giorni: 30
Ultimi 30 giorni: 123
Tutti i Tempi: 4,710
