Salta al contenuto principale
How to Reattach a Metal Rib to Fabric Panel on an Umbrella
Cosa ti serve
  1. How to Reattach a Metal Rib to Fabric Panel on an Umbrella, How to Reattach a Metal Rib to Fabric Panel on an Umbrella: passo 1, immagine 1 di 1
    • Open the umbrella and identify any metal ribs that have detached from the fabric panel.
  2. How to Reattach a Metal Rib to Fabric Panel on an Umbrella: passo 2, immagine 1 di 2 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: passo 2, immagine 2 di 2
    • Tie a knot two inches from the end of the thread.
    • Place the opposite end of the thread into a sewing needle.
    • Rubbing or wetting the end of the thread may make it easier to insert the thread into the sewing needle.
  3. How to Reattach a Metal Rib to Fabric Panel on an Umbrella: passo 3, immagine 1 di 1
    • Align the metal rib with the region of the fabric panel that it detached from.
    • If necessary, use scotch tape to secure the metal rib into position so it does not lift up.
  4. How to Reattach a Metal Rib to Fabric Panel on an Umbrella: passo 4, immagine 1 di 3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: passo 4, immagine 2 di 3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: passo 4, immagine 3 di 3
    • Be careful to avoid injury when using a sharp sewing needle.
    • Insert the sewing needle through the umbrella fabric panel and pull the thread through.
    • Poke the sewing needle through the underside of the fabric panel on the opposite side of the metal rib and pull the thread through.
  5. How to Reattach a Metal Rib to Fabric Panel on an Umbrella: passo 5, immagine 1 di 3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: passo 5, immagine 2 di 3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: passo 5, immagine 3 di 3
    • Pull the sewing needle and thread across to wrap around the metal rib.
    • Insert the sewing needle through the fabric panel and pull the thread through.
    • Repeat Steps 4 and 5 until the metal rib is tightly secured to the fabric panel. Three additional loops is recommended.
  6. How to Reattach a Metal Rib to Fabric Panel on an Umbrella: passo 6, immagine 1 di 3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: passo 6, immagine 2 di 3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: passo 6, immagine 3 di 3
    • Remove the thread from the sewing needle.
    • Tie the loose end of the string to the end of the string with the knot from Step 2.
  7. How to Reattach a Metal Rib to Fabric Panel on an Umbrella: passo 7, immagine 1 di 3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: passo 7, immagine 2 di 3 How to Reattach a Metal Rib to Fabric Panel on an Umbrella: passo 7, immagine 3 di 3
    • Don't run with scissors!
    • Use scissors to cut off any excess thread.
    • If necessary, remove any scotch tape pieces.
Conclusione
Repeat these steps if there are multiple detached metal ribs from the fabric panel. Once the repair is completed, the umbrella should work properly again.
Danielle Shapiro
Membro da: 02/18/20
148 Reputazione
1 Guida realizzata
UC Davis, Team S2-G5, Andersen Winter 2020 Membro di UC Davis, Team S2-G5, Andersen Winter 2020
UCD-ANDERSEN-W20S2G5
4 Membri
2 Guide realizzate
Un commento
What sort of thread did you use? Yours seems quite thick, a lot thicker than the standard threads.
SBN - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 48
Ultimi 30 Giorni: 160
Tutti i Tempi: 5,654
