Salta al contenuto principale
How to Reattach a Cabinet's Center Stile
Cosa ti serve
  1. How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: passo 1, immagine 1 di 3 How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: passo 1, immagine 2 di 3 How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: passo 1, immagine 3 di 3
    • Measure the width and length of the detached center stile.
  2. How to Reattach a Cabinet's Center Stile: passo 2, immagine 1 di 3 How to Reattach a Cabinet's Center Stile: passo 2, immagine 2 di 3 How to Reattach a Cabinet's Center Stile: passo 2, immagine 3 di 3
    • Mark the measurements on the wood block that will be the supporting piece.
    • You may need to extend the length of the new stile to cover several inches above and below the stile's point of attachment.
    • Follow the markings and use the hacksaw to cut down the wood block so that it is the same width as the center stile.
  3. How to Reattach a Cabinet's Center Stile: passo 3, immagine 1 di 3 How to Reattach a Cabinet's Center Stile: passo 3, immagine 2 di 3 How to Reattach a Cabinet's Center Stile: passo 3, immagine 3 di 3
    • Apply a generous amount of wood glue to one side of the wood block.
    • Spread the glue to cover the entire side of the wood.
  4. How to Reattach a Cabinet's Center Stile: passo 4, immagine 1 di 2 How to Reattach a Cabinet's Center Stile: passo 4, immagine 2 di 2
    • Place the wood piece against the back of stile and cabinet frame.
    • Use clamps to hold the center stile, cabinet frame, and wood supporting piece together.
    • The clamps prevent the wood block from sliding off the center stile so that it will dry in a fixed position.
    • Remove the clamps after 24 hours.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 54
Tutti i Tempi: 1,203
