Salta al contenuto principale
How to Reattach Loose Book Pages
Cosa ti serve
  1. How to Reattach Loose Book Pages, How to Reattach Loose Book Pages: passo 1, immagine 1 di 3 How to Reattach Loose Book Pages, How to Reattach Loose Book Pages: passo 1, immagine 2 di 3 How to Reattach Loose Book Pages, How to Reattach Loose Book Pages: passo 1, immagine 3 di 3
    • Open the book and remove the loose pages.
    • Make sure the pages are in numerical order.
    • Set the ordered loose pages aside.
  2. How to Reattach Loose Book Pages: passo 2, immagine 1 di 3 How to Reattach Loose Book Pages: passo 2, immagine 2 di 3 How to Reattach Loose Book Pages: passo 2, immagine 3 di 3
    • Squeeze some glue onto the inside of the book spine.
  3. How to Reattach Loose Book Pages: passo 3, immagine 1 di 3 How to Reattach Loose Book Pages: passo 3, immagine 2 di 3 How to Reattach Loose Book Pages: passo 3, immagine 3 di 3
    • Use a craft stick to spread the glue so that it covers the spine evenly.
  4. How to Reattach Loose Book Pages: passo 4, immagine 1 di 3 How to Reattach Loose Book Pages: passo 4, immagine 2 di 3 How to Reattach Loose Book Pages: passo 4, immagine 3 di 3
    • Set the ordered loose pages back in the spine.
    • Carefully line up the top and bottom of each loose page with those in the book.
    • You might need to wiggle or readjust them to make sure they are lined up.
    • Work quickly so that the glue doesn’t dry and cause the pages to stick in the wrong place.
  5. How to Reattach Loose Book Pages: passo 5, immagine 1 di 3 How to Reattach Loose Book Pages: passo 5, immagine 2 di 3 How to Reattach Loose Book Pages: passo 5, immagine 3 di 3
    • Place a rubber band around the book to hold it closed and to ensure pages are held in place.
    • Additionally, you can stack heavier books on top of your repaired book.
    • Let the book dry for 24 hours.
  6. How to Reattach Loose Book Pages: passo 6, immagine 1 di 2 How to Reattach Loose Book Pages: passo 6, immagine 2 di 2
    • Remove the heavy books and rubber band.
  7. How to Reattach Loose Book Pages: passo 7, immagine 1 di 1
    • Gently flip through your book. The pages should feel secure.
    • If the pages don’t feel secure you can repeat steps 1 through 6.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Un commento
Thank you , very useful . Be Lucky 🍀 Glenn.
chuckle.tometoyou - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 104
Ultimi 30 Giorni: 505
Tutti i Tempi: 13,100
