Salta al contenuto principale
How to Reassemble the Palm IIIc
Cosa ti serve
  1. How to Reassemble the Palm IIIc, How to Reassemble the Palm IIIc: passo 1, immagine 1 di 1
    • Reinsert the screen into the case that contains the buttons.
  2. How to Reassemble the Palm IIIc: passo 2, immagine 1 di 1
    • Put the Motherboard back into casing from right to left.
    • Make sure the black clips are securing the motherboard into the casing.
  3. How to Reassemble the Palm IIIc: passo 3, immagine 1 di 3 How to Reassemble the Palm IIIc: passo 3, immagine 2 di 3 How to Reassemble the Palm IIIc: passo 3, immagine 3 di 3
    • Secure the bottom two ZIF connectors into their slots by opening the flap and inserting the ZIF connectors.
    • Gently press down on the flap to secure the ZIF connector. This secures the screen and buttons to the motherboard.
  4. How to Reassemble the Palm IIIc: passo 4, immagine 1 di 2 How to Reassemble the Palm IIIc: passo 4, immagine 2 di 2
    • Connect the blue and red screen cables to the beige box they were removed from.
  5. How to Reassemble the Palm IIIc: passo 5, immagine 1 di 2 How to Reassemble the Palm IIIc: passo 5, immagine 2 di 2
    • Open the ZIF connector box at the top of the motherboard by gently pulling up on the flap.
    • Insert the ZIF tab into the connector box.
    • Gently press down on the flap to secure the ZIF tab in place.
  6. How to Reassemble the Palm IIIc: passo 6, immagine 1 di 1
    • Attach the white box on the end of the red cable connected to the battery into the connector box on the motherboard.
  7. How to Reassemble the Palm IIIc: passo 7, immagine 1 di 1
    • Place the front and back covers around the casing containing the motherboard and screen.
    • Before securing the covers, place the sensor in between the front and back cover at the top of the device.
    • After the sensor is in place between the two covers, firmly secure the front and back covers.
  8. How to Reassemble the Palm IIIc: passo 8, immagine 1 di 1
    • Replace the long screws at the top of the back case with the Philips head screwdriver.
    • Replace the short screws to the bottom of the back case using the Philips head screwdriver.
    • After the screws are in place, insert the stylus.
  9. How to Reassemble the Palm IIIc: passo 9, immagine 1 di 1
    • Gently snap the flip cover back into place where it connects at the top of the Palm IIIc
Linea Traguardo
Angela Arthur
Membro da: 02/16/12
101 Reputazione
1 Guida realizzata
Ohio State, Team 1-5, Buehl Winter 2012 Membro di Ohio State, Team 1-5, Buehl Winter 2012
OSU-BUEHL-W12S1G5
5 Membri
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 319
