Parti
Nessuna parte richiesta.
Reinsert the screen into the case that contains the buttons.
  • Reinsert the screen into the case that contains the buttons.
Aggiungi Commento
Put the Motherboard back into casing from right to left.
  • Put the Motherboard back into casing from right to left.
  • Make sure the black clips are securing the motherboard into the casing.
Aggiungi Commento
  • Secure the bottom two ZIF connectors into their slots by opening the flap and inserting the ZIF connectors.
    • Gently press down on the flap to secure the ZIF connector. This secures the screen and buttons to the motherboard.
Aggiungi Commento
  • Connect the blue and red screen cables to the beige box they were removed from.
Aggiungi Commento
  • Open the ZIF connector box at the top of the motherboard by gently pulling up on the flap.
  • Insert the ZIF tab into the connector box.
  • Gently press down on the flap to secure the ZIF tab in place.
Aggiungi Commento
  • Attach the white box on the end of the red cable connected to the battery into the connector box on the motherboard.
Aggiungi Commento
  • Place the front and back covers around the casing containing the motherboard and screen.
  • Before securing the covers, place the sensor in between the front and back cover at the top of the device.
  • After the sensor is in place between the two covers, firmly secure the front and back covers.
Aggiungi Commento
  • Replace the long screws at the top of the back case with the Philips head screwdriver.
  • Replace the short screws to the bottom of the back case using the Philips head screwdriver.
  • After the screws are in place, insert the stylus.
Aggiungi Commento
  • Gently snap the flip cover back into place where it connects at the top of the Palm IIIc
Aggiungi Commento
Linea Traguardo
Angela Arthur
Membro da: 16/02/2012
101 Reputazione
1 Guida realizzata
Ohio State, Team 1-5, Buehl Winter 2012 Membro di Ohio State, Team 1-5, Buehl Winter 2012
OSU-BUEHL-W12S1G5
5 Membri
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 78
