Salta al contenuto principale
How to Re-attach Delaminated Layers on a Foam Camping Mat
Cosa ti serve
  1. How to Re-attach Delaminated Layers on a Foam Camping Mat, Identify the repair area: passo 1, immagine 1 di 3 How to Re-attach Delaminated Layers on a Foam Camping Mat, Identify the repair area: passo 1, immagine 2 di 3 How to Re-attach Delaminated Layers on a Foam Camping Mat, Identify the repair area: passo 1, immagine 3 di 3
    • Locate the delaminated part that needs to be fixed.
    • Choose a suitable glue that adheres to foam surfaces.
    • Note: in this example, we choose a spray glue, but any foam-adapted glue will work just the same.
  2. How to Re-attach Delaminated Layers on a Foam Camping Mat, Prepare the area for spraying: passo 2, immagine 1 di 3 How to Re-attach Delaminated Layers on a Foam Camping Mat, Prepare the area for spraying: passo 2, immagine 2 di 3 How to Re-attach Delaminated Layers on a Foam Camping Mat, Prepare the area for spraying: passo 2, immagine 3 di 3
    • Place a piece of paper or old newspaper under the mat to protect the surface before spraying.
    • Tip: leave a distance of 20-30 cm around the mat when spraying.
    • Place a small piece of cardboard between the tip and the rest of the mat to prevent the spray glue from directly staining it.
  3. How to Re-attach Delaminated Layers on a Foam Camping Mat, Apply the glue: passo 3, immagine 1 di 2 How to Re-attach Delaminated Layers on a Foam Camping Mat, Apply the glue: passo 3, immagine 2 di 2
    • Spray the delaminated area with the foam glue.
  4. How to Re-attach Delaminated Layers on a Foam Camping Mat, Secure the attachment: passo 4, immagine 1 di 3 How to Re-attach Delaminated Layers on a Foam Camping Mat, Secure the attachment: passo 4, immagine 2 di 3 How to Re-attach Delaminated Layers on a Foam Camping Mat, Secure the attachment: passo 4, immagine 3 di 3
    • Apply pressure to the area.
    • Note: Follow the instructions of the glue used to know the exact drying time. In this example, we waited 1 minute for the glue to dry before attaching both layers together. Afterwards, we held the parts together for 3 minutes and then let it dry overnight.
  5. How to Re-attach Delaminated Layers on a Foam Camping Mat, Finished and ready!: passo 5, immagine 1 di 3 How to Re-attach Delaminated Layers on a Foam Camping Mat, Finished and ready!: passo 5, immagine 2 di 3 How to Re-attach Delaminated Layers on a Foam Camping Mat, Finished and ready!: passo 5, immagine 3 di 3
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusione
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
Membro da: 07/19/23
10.230 Reputazione
66 Guide realizzate
INTERSPORT Membro di INTERSPORT
Community
25 Membri
169 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 134
