Salta al contenuto principale
How to Properly Clean the Airox Legendair
Attrezzature medicali
Né iFixit né questa guida di riparazione sono approvati dal produttore del dispositivo medicale o affiliati ad esso.
Cosa ti serve
  1. How to Properly Clean the Airox Legendair, How to Properly Clean the Airox Legendair: passo 1, immagine 1 di 1
    • First, switch off the device.
    • Place the device in a clean and open environment.
  2. How to Properly Clean the Airox Legendair: passo 3, immagine 1 di 1
    • Using a cloth or a sponge slightly dampened with a bactericide or germicide solution, gently clean the outside of the device.
  3. How to Properly Clean the Airox Legendair: passo 4, immagine 1 di 1
    • If necessary, spray the device lightly with the germicide solution, taking account of the requirements discussed in the preliminary operations.
    • Do not allow any liquid to enter inside the device (in particular through the cooling apertures).
    • Use a gentle air blast to clear away any remaining liquid from ventilator.
Conclusione
Make sure the ventilator is in good visual condition upon thorough cleaning of the machine.
Cal Poly, Team S7-G15, Paton Spring 2020 Membro di Cal Poly, Team S7-G15, Paton Spring 2020
CPSU-PATON-S20S7G15
3 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 227
