Salta al contenuto principale
How to Propagate a Plant in Water
Cosa ti serve
  1. How to Propagate a Plant in Water, How to Propagate a Plant in Water: passo 1, immagine 1 di 2 How to Propagate a Plant in Water, How to Propagate a Plant in Water: passo 1, immagine 2 di 2
    • Using scissors or shears cut the plant below a node.
    • Node: a point where a leaf or branch emerges.
  2. How to Propagate a Plant in Water: passo 2, immagine 1 di 2 How to Propagate a Plant in Water: passo 2, immagine 2 di 2
    • Remove the bottom leaves and cut the plant diagonally.
    • Cutting the plant in a diagonal will increase surface area and allow for better water consumption.
  3. How to Propagate a Plant in Water: passo 3, immagine 1 di 2 How to Propagate a Plant in Water: passo 3, immagine 2 di 2
    • Optional: Coat the cutting in rooting powder.
    • Rooting powder will accelerate the rooting process and yield a higher success rate.
  4. How to Propagate a Plant in Water: passo 4, immagine 1 di 1
    • Fill a glass cup with water.
  5. How to Propagate a Plant in Water: passo 5, immagine 1 di 1
    • Place the cutting in the cup.
    • The cup should be in a well-ventilated area with bright indirect light.
    • Change the water every week to prevent bacterial growth.
  6. How to Propagate a Plant in Water: passo 6, immagine 1 di 2 How to Propagate a Plant in Water: passo 6, immagine 2 di 2
    • Once the roots are 1-2 inches long, transfer to medium (soil, lecca, etc.).
    • Water regularly to reduce shock.
Conclusione
You did it! Congratulations on successfully propagating your plant in water!
Altre 5 persone hanno completato questa guida.
Daniela Perez
Membro da: 02/21/24
235 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 104
Tutti i Tempi: 1,570
